Hush_Chen
When using batch mode simulation, I can't see the source code in simulator.
My script as follows,
xelab work.my_design_tb -prj simulate_xsim.prj -debug all -s my_design_tb
xsim -g -wdb sim.wdb my_design_tb -view sim.wcfg
When I launch the simulator using batch file as above, I can't see the source code in Sources page.
I want to try break point in line function. How can I solve it?
graces
If you want cross probing to source code, I'd suggest that you run simulation in project mode.
graces
Hush_Chen
Hi Graces,
I got it. When using non-project mode, I can't link debug to line using "xelab -debug all".
