Where can I find matched simulation tool document?
For example, I use zcu102 board, and use vivado 2017.4, Now I want to know which version simulation tool(like modelsim, questasim, vcs, incisive) can match vivado2017.4?
In document navigator, I find ug900 about logic simulation, but not found simulation tool version.
Re: Where can I find matched simulation tool document?
Hi @luoyanghero ,
That information can be found that info in UG973(Chapter-2), please check the below link for all version of the UG:
https://www.xilinx.com/support/documentation-navigation/see-all-versions.html?xlnxproducttypes=Design%20Tools&xlnxdocumentid=UG973
Raj
Hi @luoyanghero ,
Raj
