Observer mostafa@sint
Where is FFT v9.1 test bench?
Hi All,
There are allways mentioned in forums that use FFT IP core testbench in
demo_tb/
tb_<component_name>.vhd
but I have just made a block design with its HDL wrapper but cant find demo_tb directory
and test bench file.
I am using windows 10 and vivado 2018.2.2.
Mostafa
Tags (3)
Re: Where is FFT v9.1 test bench?
finally I found that when you use an IP in a block diagram design,
it  doesnt generate the test bench. But if you follow the following video for IP instantiation then
you can see the test bench is generated.
https://www.youtube.com/watch?v=-NaRIrFSZ38
Learn how to customize, add and instantiate IP into a project using the IP Catalog. Specifically, the features highlighted include: launch IP Catalog, search and select an IP, customize an IP, add IP to a design, instantiate an IP into a project, creating a standalone IP project and generating a ...
Hi mostafa@sint,
Can you please check the below forum threads and see if it helps:
https://forums.xilinx.com/t5/Simulation-and-Verification/How-to-generate-demonstration-testbench-for-LogiCORE-FFT-IP-in/td-p/733841
https://forums.xilinx.com/t5/Simulation-and-Verification/How-to-use-IP-Core-simulation-sources/td-p/895522
Thanks & Regards,
Sravanthi B
Hi Bandi,
The problem is that there is no testbench in simulations
even after generating output products.
Its strange but there is not tb_demo directory as well in the project directory.
Mostafa
the problem ia solved now.
