Whether Zynq BFM supports Questsim 10.3d
Whether Zynq BFM supports Questsim 10.3d?
Re: Whether Zynq BFM supports Questsim 10.3d
check this guide . Its depends upon tool versions
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug973-vivado-release-notes-install-license.pdf
Thanks and Regards
Balkrishan
Yes, it does support!
Debraj
