acraddick23
Why can't simulation find ports from IP?
I am being told that the behavioral simulation cannot find ports I instantiated from the XADC IP despite the ports clearing being declared in the module and their names matching.
This is the file I'm instantiating in the testbench:
module XADC_simulation(
output wire m_axis_tvalid,
input wire m_axis_tready,
output wire [15 : 0] m_axis_tdata,
output wire [4 : 0] m_axis_tid,
input wire m_axis_aclk,
input wire s_axis_aclk,
input wire m_axis_resetn,
input wire dclk_in,
input wire [15 : 0] di_in,
input wire [6 : 0] daddr_in,
input wire den_in,
input wire dwe_in,
output wire drdy_out,
output wire [15 : 0] do_out,
input wire vp_in,
input wire vn_in,
input wire vauxp6,
input wire vauxn6,
output wire [4 : 0] channel_out,
output wire eoc_out,
output wire alarm_out,
output wire eos_out,
output wire busy_out
xadc_wiz_0 your_instance_name (
.m_axis_tvalid(m_axis_tvalid),
.m_axis_tready(m_axis_tready),
.m_axis_tdata(m_axis_tdata),
.m_axis_tid(m_axis_tid),
.m_axis_aclk(m_axis_aclk),      //
.s_axis_aclk(m_axis_aclk),      //
.m_axis_resetn(m_axis_resetn),  //
.dclk_in(dclk_in),
.di_in(16'h0),
.daddr_in({2'b00,channel_out}),
.den_in(eoc_out),
.dwe_in(1'b0),
.drdy_out(drdy_out),
.do_out(do_out),
.vp_in(1'b0),
.vn_in(1'b0),
.vauxp6(vauxp6),
.vauxn6(vauxn6),
.channel_out(channel_out),
.eoc_out(eoc_out),
.alarm_out(alarm_out),
.eos_out(eos_out),
.busy_out(busy_out)
And this is the testbench file:
module XADC_tb(
wire m_axis_tvalid;
reg m_axis_tready;
wire [15 : 0] m_axis_tdata;
wire [4 : 0] m_axis_tid;
reg dclk_in;
//reg s_axis_aclk;
wire [15 : 0] di_in;
reg [6 : 0] daddr_in;
reg den_in;
reg dwe_in;
wire drdy_out;
wire [15 : 0] do_out;
reg vp_in;
reg vn_in;
reg vauxp6;
reg vauxn6;
wire [4 : 0] channel_out;
wire eoc_out;
wire alarm_out;
wire eos_out;
wire busy_out;
XADC_simulation UUT (
//.s_axis_aclk(s_axis_aclk),
.dclk_in(dclk_in),
.di_in(16'h0),
.den_in(eoc_out),
.dwe_in(1'b0),
.do_out(do_out),
.vp_in(vp_in),
.vn_in(vn_in),
.vauxp6(vauxp6),
.vauxn6(vauxn6),
.eoc_out(eoc_out),
.eos_out(eos_out),
.busy_out(busy_out)
initial  begin
    dclk_in = m_axis_aclk;
    dclk_in = 1'b0;
    forever #10 dclk_in = ~dclk_in;
end
endmodule
When I try to run a behavioral simulation (which includes a design.txt file for sample data) I am told:
  • [VRFC 10-3180] cannot find port 'm_axis_resetn' on this module ["C:/Xilinx/Vivado/XADC_to_display/XADC_to_display.srcs/sources_1/new/XADC_simulation.v":41]
  • [VRFC 10-3180] cannot find port 's_axis_aclk' on this module ["C:/Xilinx/Vivado/XADC_to_display/XADC_to_display.srcs/sources_1/new/XADC_simulation.v":40]
  • [VRFC 10-3180] cannot find port 'm_axis_aclk' on this module ["C:/Xilinx/Vivado/XADC_to_display/XADC_to_display.srcs/sources_1/new/XADC_simulation.v":39]
  • [VRFC 10-3180] cannot find port 'm_axis_tid' on this module ["C:/Xilinx/Vivado/XADC_to_display/XADC_to_display.srcs/sources_1/new/XADC_simulation.v":38]
  • [VRFC 10-3180] cannot find port 'm_axis_tdata' on this module ["C:/Xilinx/Vivado/XADC_to_display/XADC_to_display.srcs/sources_1/new/XADC_simulation.v":37]
  • [VRFC 10-3180] cannot find port 'm_axis_tready' on this module ["C:/Xilinx/Vivado/XADC_to_display/XADC_to_display.srcs/sources_1/new/XADC_simulation.v":36]
  • [VRFC 10-3180] cannot find port 'm_axis_tvalid' on this module ["C:/Xilinx/Vivado/XADC_to_display/XADC_to_display.srcs/sources_1/new/XADC_simulation.v":35]
When I run the exact same testbench without the AXI signals (regenerate the IP without AXI4-Streaming enabled) and use only the DRP signals it has no problem finding the ports.
If I remove one of the DRP signals (such as dclk_in for example) from the port list in the XADC_simulation the errors include that as a missing port naturally but why is it including the AXI signals when they're obviously defined?
graces
If the ports do match the XADC IP interface, my suggestion would be to disable incremental compilation.
Go to Simulation Settings. Click Advanced tab and uncheck "Enable incremental compilation".
acraddick23
@graces Thanks for the response! I unchecked "Enable incremental compilation" as you said but I still get the exact same error messages. The simulation fails on the elaboration step.
graces
Would you please provide a test case to reproduce the failure?
