Write testbench in C for rtl design
Hi All,
I would like to no if it's possible to write a vivado testbench for a normal rtl design in C (or even python). I found that you can do it for designs created in the HLS but is it possible
also for designs that are not generated in HLS ?
Thanks in advance
--JohnXio
Re: Write testbench in C for rtl design
HI @johnxio ,
The Xilinx Simulator Interface (XSI) is a C/C++ application programming interface (API) to
the Xilinx Vivado Simulator (xsim) that enables a C/C++ program to serve as the test bench
for a HDL design.
For more information, please refer the below user guide Appendix-I page#249:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug900-vivado-logic-simulation.pdf
Thanks & Regards,
Sravanthi B
Voyager
Voyager
I am unaware of any way to simulate RTL design files with a testbench written in C or Python.
HLS is the closest thing to that in that it uses C testbenches, but HLS will not load RTL files.
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
The answer to your question is "yes", in that Vivado supports the SystemVerilog Direct Programming Interface (DPI). You would create a SV testbench and instantiate your RTL, whether it be Verilog, SystemVerilog, or VHDL, inside it. Then use the DPI to interface with your C test program.
See here for more information.
Scholar richardhead
While not supported at all in Vivado, if you want to use Python then there is Vunit as a python based testing framework for HDL designs.
https://vunit.github.io/
Then there is MyHDL where entire designs can be be written and tested in python (it generates HDL to allow synthesis, but all of the source can be written in python)
http://www.myhdl.org/
HI @johnxio ,
for a HDL design.
Thanks & Regards,
Sravanthi B
Hi @richardhead
as an addition to your wonderful solutions I found also: https://cocotb.readthedocs.io/en/latest/introduction.html
Cheers
--JohnXio
Hi Everybody,
thanks for the nice replies and suggestions, I will take a look on all those and find what is the best solution to test my HDL design. For the moment I will close the thread by accepting the official Xilinx solution.
Cheers
--Ioannis
