XADC proper simulation
Hi guys,
From a while I am trying to find a way to simulate the xadc and i have not found a proper way and hence I tried again and here is the status
here is my block diagram, here is my project manager pic
here is my design_1_wrapper.vhd
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
library UNISIM;
use UNISIM.VCOMPONENTS.ALL;
entity design_1_wrapper is
port (
dclk_in : in STD_LOGIC;
vn_in : in STD_LOGIC;
vp_in : in STD_LOGIC
end design_1_wrapper;
architecture STRUCTURE of design_1_wrapper is
component design_1 is
port (
end component design_1;
begin
design_1_i: component design_1
port map (
dclk_in => dclk_in,
vn_in => vn_in,
vp_in => vp_in
end STRUCTURE;
and here is my testbench
library IEEE;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
library UNISIM;
use UNISIM.VComponents.all;
entity XADC_test_tb is
-- Port ( );
end XADC_test_tb;
architecture Behavioral of XADC_test_tb is
component design_1_xadc_wiz_0_0
port (
vp_in : in STD_LOGIC);
end component;
signal eoc : STD_LOGIC ;
constant clk_period : time := 0.1ns;
begin
uut: design_1_xadc_0_0 port map(
dclk_in => dclk_in,
vp_in => vp_in,
vn_in => vn_in
clk: process
begin
dclk_in <= '0';
wait for clk_period/2;
dclk_in <= '1';
end process;
end Behavioral;
here is my log
INFO: [VRFC 10-163] Analyzing VHDL file "E:/Xilinx_new/the_mission/level_2/GO_5/XADC_test/XADC_test.srcs/sim_1/imports/new/XADC_test_tb.vhd" into library xil_defaultlib
INFO: [VRFC 10-307] analyzing entity XADC_test_tb
ERROR: [VRFC 10-91] design_1_xadc_0_0 is not declared [E:/Xilinx_new/the_mission/level_2/GO_5/XADC_test/XADC_test.srcs/sim_1/imports/new/XADC_test_tb.vhd:51]
ERROR: [VRFC 10-91] dclk_in is not declared [E:/Xilinx_new/the_mission/level_2/GO_5/XADC_test/XADC_test.srcs/sim_1/imports/new/XADC_test_tb.vhd:58]
ERROR: [VRFC 10-91] dclk_in is not declared [E:/Xilinx_new/the_mission/level_2/GO_5/XADC_test/XADC_test.srcs/sim_1/imports/new/XADC_test_tb.vhd:60]
ERROR: [VRFC 10-1504] unit behavioral ignored due to previous errors [E:/Xilinx_new/the_mission/level_2/GO_5/XADC_test/XADC_test.srcs/sim_1/imports/new/XADC_test_tb.vhd:38]
INFO: [VRFC 10-240] VHDL file E:/Xilinx_new/the_mission/level_2/GO_5/XADC_test/XADC_test.srcs/sim_1/imports/new/XADC_test_tb.vhd ignored due to errors
INFO: [USF-XSim-69] 'compile' step finished in '2' seconds
INFO: [USF-XSim-99] Step results log file:'E:/Xilinx_new/the_mission/level_2/GO_5/XADC_test/XADC_test.sim/sim_1/behav/xvhdl.log'
ERROR: [USF-XSim-62] 'compile' step failed with error(s). Please check the Tcl console output or 'E:/Xilinx_new/the_mission/level_2/GO_5/XADC_test/XADC_test.sim/sim_1/behav/xvhdl.log' file for more information.
ERROR: [Vivado 12-4473] Detected error while running simulation. Please correct the issue and retry this operation.
ERROR: [Common 17-39] 'launch_simulation' failed due to earlier errors.
please someone help me out here. I have various permutation combination to try declare the not declared and I fail every time.
what am i doing wrong here?
Hi @benaka
In your testbench, you declare component of design_1_xadc_wiz_0_0, but you instantiate component with name of design_1_xadc_0_0 in your testbench. Their name should be the same.
You can instantiate your wrapper module, design_1_wrapper in your testbench, like this:
component design_1_wrapper
port(...)
end component;
begin
uut: design_1_wrapper port map(.....);
Hi @martinwe
I made a few changes in the tb as u mentioned and here it is
1)
2) Generated wrapper
3) the project window
As seen i till see the uut in missing sources indication.
4) and the tcl console shows me error
I still am not sure where am I going wrong.
thanks in advance.
dck_in, vp_in and vn_in should be declared in testbench:
signal dclk_in, vp_in, vn_in : std_logic;
Yes, I just found out the same, I came to answer it here and see you already mentioned.
But It still doesnt help in simulation of the signals with the .txt file but.
and the test file data here,
the project manager window here,
 when I run the simulation , the xadc still doesn't take the values.
what am I doing wrong? or why is this happening?
Thanks in advance.
For simulation of XADC, analog signals are read from a file by the simulation model. The SIM_MONITOR_FILE attribute used in the XADC instantiation points the model to the location of this file known as the Analog Stimulus file. You can find the description of this situation in ug480.
Hi @martinwe,
Here is my test bench
https://forums.xilinx.com/t5/Simulation-and-Verification/XADC-proper-simulation/m-p/893370/highlight/true#M23601
 I am not sure what do you mean by driving the signal, the data for these pins are supposed to be taken from that .txt file right?
Or can you please show me how to drive the signals that you mean.
Thanks in advance.
For the topic of stimuli file for XADC_wiz, refer to another post:
https://forums.xilinx.com/t5/Simulation-and-Verification/XADC-SIMULATION/m-p/897078#M23758
