jbaramidze
XPower gives error when reading vcd
Hello, I'm trying to do accurate power analysis via xpower.
I'm using ISE P.20131013. and xpwr: Release 14.7  P.20131013 (lin64)
So I have my core module, which I synthesize. I wrap it in testbench, run simulation and dump vcd file via commands:
vcd dumpfile ..
vcd dumpvars -m /testbench/my_core/
vcd dumpon
run all
vcd dumpflush
vcd dumpoff
then I turn off simulation tool and launch XPower via:
xpwr -s myvcd.vcd data.ncd data.pcf
but I get following errors:
WARNING:Power:216 - VCDFile(18970): $dumpoff command encountered, all simulation data after this will be ignored.
ERROR:Power:972 - Parsing Error parse error, unexpected WORD, expecting END or TRANSITION or BINARY_VALUE or REAL_VALUE line 18973 Expected
scalar or vector value change here
ERROR:Power:85 - Error reading VCD file, no simulation data will be applied.
WARNING:PowerEstimator:270 - Power estimate is considered inaccurate. To see details, generate an advanced report with the "-v" switch.
Number of error messages: 2
Number of warning messages: 2
Number of info messages: 1
on 18973 line in vcd file there is:
1!
#3599000
0!
#3600000
$dumpoff
x!
x"
x #                       << this one
x $
x %
x &
what am I doing wrong? Thanks in advance!
