kinkeads
XSIM 43-3241 error: gthe4_channel_002.vp Node SIM_VERSION is not annotated
Xsim generates the following error during elaboration of my design.   The design contains a Chip2Chip bridge using GTH transceivers.   The simulation testbench is written in System Verilog.
ERROR: [XSIM 43-3241] File /wrk/2017.1/nightly/2017_04_14_1846317/data/secureip/gthe4_channel/gthe4_channel_002.vp, Line Num 22892, Node SIM_VERSION is not annotated.
kinkeads
After opening a support ticket, I was told this is a known bug and will be fixed in 2017.3.
There is a work-around.  The error only occurs during mixed-mode simulations.  Set the target language to Verilog and regenerate all the outputs so there are no VHDL source files, and then simulation should run.
vijayak
Hi @kinkeads
Please check if the following AR is applicable to you.
https://www.xilinx.com/support/answers/63972.html
Thanks,Vijay
kinkeads
AR 63972 recommends overriding the SIM_VERSION parameter value, but I do not see this property on any devices in my IP Integrator block design.
Is SIM_VERSION a property attached to an IP block?  I would expect it to be on the AURORA_64B66B IP block since it contains the GT transceivers.
Thanks!
kinkeads
