[XSIM 43-3294] Signal EXCEPTION_ACCESS_VIOLATION received using Vivado 2017.3
When simulating fairly large project using Vivado 2017.3 using multiple .sv files, I get error below. I have attached source for sim_services_package.sv where the error appears to originate from. Please help on identifying what could be causing the issue?
Compiling package xil_defaultlib.sim_services_package
ERROR: [XSIM 43-3294] Signal EXCEPTION_ACCESS_VIOLATION received.
Printing stacktrace...
[0] (KiUserExceptionDispatcher+0x2e) [0x77b5b61e]
[1] (ISIMC::VlogCompiler::transform+0xd63f9) [0x13f86ecb9]
[2] (ISIMC::VlogCompiler::transform+0xe7c08) [0x13f8804c8]
[3] (ISIMC::VlogCompiler::transform+0x13dfa6) [0x13f8d6866]
[4] (ISIMC::VlogCompiler::transform+0x13de10) [0x13f8d66d0]
[5] (ISIMC::VlogCompiler::transform+0x13df6b) [0x13f8d682b]
[6] (ISIMC::VlogCompiler::transform+0x1236ad) [0x13f8bbf6d]
[7] (ISIMC::VlogCompiler::transform+0x11ef40) [0x13f8b7800]
[8] (ISIMC::VlogCompiler::transform+0xf20a1) [0x13f88a961]
[9] (ISIMC::VlogCompiler::codegen+0x446) [0x13f789ec6]
[10] (ISIMC::Options::parseVlogcompCommandLine+0xd91ed) [0x13fa7c95d]
[11] (ISIMC::Options::parseVlogcompCommandLine+0xd7e8c) [0x13fa7b5fc]
[12] (ISIMC::Options::parseVlogcompCommandLine+0xd8108) [0x13fa7b878]
[13] (ISIMC::VhdlCompiler::saveParserDump+0x8e2ee) [0x13f98807e]
[14]  [0x13f717f05]
[15]  [0x13f729774]
[16]  [0x13f72806a]
[17] (ISIMC::Options::parseVlogcompCommandLine+0xa96fa9) [0x14043a719]
[18] (BaseThreadInitThunk+0xd) [0x779e59cd]
Done
0x000000013F86ECB9 (0x000000000160BE90 0x00000002089D8F70 0x000000000160BEB0 0x000000013FAA1865), ISIMC::VlogCompiler::transform() + 0xD63F9 bytes(s)
0x000000013F8804C8 (0x0000000038D3F0E8 0x000000000160C3A0 0x000000000160C3A0 0x00000000037D0420), ISIMC::VlogCompiler::transform() + 0xE7C08 bytes(s)
0x000000013F8D6866 (0x0000000000000000 0x000000000030004C 0x0000000000000000 0x0000000006EF5E80), ISIMC::VlogCompiler::transform() + 0x13DFA6 bytes(s)
0x000000013F8D66D0 (0x000000000160C3A0 0x0000000000000001 0x000000000160C300 0x00000000037D0380), ISIMC::VlogCompiler::transform() + 0x13DE10 bytes(s)
0x000000013F8D682B (0x000000000160C090 0x0000000000300048 0x00000000037A07A0 0x000000000160C090), ISIMC::VlogCompiler::transform() + 0x13DF6B bytes(s)
0x000000013F8BBF6D (0x0000000000000000 0x0000000038D3DEF0 0x0000000038D3DF30 0x000000023D754DB0), ISIMC::VlogCompiler::transform() + 0x1236AD bytes(s)
0x000000013F8B7800 (0x000000000160C390 0x000000000160C200 0x000000000000000B 0x0000000000000001), ISIMC::VlogCompiler::transform() + 0x11EF40 bytes(s)
0x000000013F88A961 (0x000000000160C350 0x000000000160C4E0 0x000000000160CA20 0x000000000160E930), ISIMC::VlogCompiler::transform() + 0xF20A1 bytes(s)
0x000000013F789EC6 (0x000000000160CA20 0x000000000160CA20 0x00000000B0103CC0 0x000000000160CA20), ISIMC::VlogCompiler::codegen() + 0x446 bytes(s)
0x000000013FA7C95D (0x000000001B786B80 0x00000000B175FF80 0x000000000FF98DB0 0x000000000160CB58), ISIMC::Options::parseVlogcompCommandLine() + 0xD91ED bytes(s)
0x000000013FA7B5FC (0x000000001B786B80 0x000000000160CA20 0x000000000160CA20 0x00000000161818E0), ISIMC::Options::parseVlogcompCommandLine() + 0xD7E8C bytes(s)
0x000000013FA7B878 (0x0000000000000000 0x000000000160C6F0 0x00000000161818E0 0x0000000001781740), ISIMC::Options::parseVlogcompCommandLine() + 0xD8108 bytes(s)
0x000000013F98807E (0x0000000000000000 0x000000000160D830 0x000000000160DDB0 0x3E5C028529D81985), ISIMC::VhdlCompiler::saveParserDump() + 0x8E2EE bytes(s)
0x000000013F717F05 (0x000000000160DDB0 0x000000000160DDB0 0x000000000160DDF0 0x0000000140B7A6A0)
0x000000013F729774 (0x0000000000000019 0x0000000000000019 0x0000000000000000 0x000000000177CEB0)
0x000000013F72806A (0x0000000000000000 0x0000000000000000 0x000007FEF86869F8 0x01D4BB1699A4593E)
0x000000014043A719 (0x0000000000000000 0x0000000000000000 0x0000000000000000 0x0000000000000000), ISIMC::Options::parseVlogcompCommandLine() + 0xA96FA9 bytes(s)
0x00000000779E59CD (0x0000000000000000 0x0000000000000000 0x0000000000000000 0x0000000000000000), BaseThreadInitThunk() + 0xD bytes(s)
0x0000000077B4385D (0x0000000000000000 0x0000000000000000 0x0000000000000000 0x0000000000000000), RtlUserThreadStart() + 0x1D bytes(s)
run_program: Time (s): cpu = 00:01:39 ; elapsed = 00:36:17 . Memory (MB): peak = 1136.148 ; gain = 16.125
Re: [XSIM 43-3294] Signal EXCEPTION_ACCESS_VIOLATION received using Vivado 2017.3
Hi iavendano@aidinc-usa.com,
Can you please share the complete test case rather than the package file alone to check this issue at our end ?
