[XSIM 43-3316] Signal SIGSEGV received. during elab
I am getting a segmentation fault during elab command. My command looks like
xvlog --sv -f filelist.f
My filelist has a mix of verilog and system verilog files (a dummy filelist.f is as follows)
verilog_file1.v
verilog_file2.v
sv_file2.sv
... the stack trace with the error message is as follows
[0] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4e89be]
[1] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x502693]
[2] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x50226b]
[3] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x503ced]
[4] /opt/Xilinx/Vivado/2017.2/lib/lnx64.o/libxsimverific.so(Verific::VeriVisitor::TraverseArray(Verific::Array const*)+0x86) [0x7f01b95883a6]
[5] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4f9af0]
[6] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4ea85d]
[7] /opt/Xilinx/Vivado/2017.2/lib/lnx64.o/libxsimverific.so(Verific::VeriVisitor::TraverseArray(Verific::Array const*)+0x86) [0x7f01b95883a6]
[8] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4f9af0]
[9] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4ea85d]
[10] /opt/Xilinx/Vivado/2017.2/lib/lnx64.o/libxsimverific.so(Verific::VeriVisitor::TraverseArray(Verific::Array const*)+0x86) [0x7f01b95883a6]
[11] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4f9af0]
[12] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4ea85d]
[13] /opt/Xilinx/Vivado/2017.2/lib/lnx64.o/libxsimverific.so(Verific::VeriVisitor::TraverseArray(Verific::Array const*)+0x86) [0x7f01b95883a6]
[14] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4f9af0]
[15] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4ea85d]
[16] /opt/Xilinx/Vivado/2017.2/lib/lnx64.o/libxsimverific.so(Verific::VeriVisitor::TraverseArray(Verific::Array const*)+0x86) [0x7f01b95883a6]
[17] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4f9af0]
[18] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4ea85d]
[19] /opt/Xilinx/Vivado/2017.2/lib/lnx64.o/libxsimverific.so(Verific::VeriVisitor::TraverseArray(Verific::Array const*)+0x86) [0x7f01b95883a6]
[20] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4f9af0]
[21] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4ea85d]
[22] /opt/Xilinx/Vivado/2017.2/lib/lnx64.o/libxsimverific.so(Verific::VeriVisitor::TraverseArray(Verific::Array const*)+0x86) [0x7f01b95883a6]
[23] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4f9af0]
[24] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4ea85d]
[25] /opt/Xilinx/Vivado/2017.2/lib/lnx64.o/libxsimverific.so(Verific::VeriVisitor::TraverseArray(Verific::Array const*)+0x86) [0x7f01b95883a6]
[26] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4f9af0]
[27] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4ea85d]
[28] /opt/Xilinx/Vivado/2017.2/lib/lnx64.o/libxsimverific.so(Verific::VeriVisitor::TraverseArray(Verific::Array const*)+0x86) [0x7f01b95883a6]
[29] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4f9af0]
[30] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4ea85d]
[31] /opt/Xilinx/Vivado/2017.2/lib/lnx64.o/libxsimverific.so(Verific::VeriVisitor::TraverseArray(Verific::Array const*)+0x86) [0x7f01b95883a6]
[32] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4f9af0]
[33] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4ea85d]
[34] /opt/Xilinx/Vivado/2017.2/lib/lnx64.o/libxsimverific.so(Verific::VeriVisitor::TraverseArray(Verific::Array const*)+0x86) [0x7f01b95883a6]
[35] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4f9af0]
[36] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4ea85d]
[37] /opt/Xilinx/Vivado/2017.2/lib/lnx64.o/libxsimverific.so(Verific::VeriVisitor::TraverseArray(Verific::Array const*)+0x86) [0x7f01b95883a6]
[38] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4f9af0]
[39] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4e6071]
[40] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4813a4]
[41] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4677c2]
[42] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x4760c6]
[43] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x44b9ff]
[44] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f01b7aa0830]
[45] /opt/Xilinx/Vivado/2017.2/bin/unwrapped/lnx64.o/xelab() [0x465631]
Can someone please help with this issue?
Re: [XSIM 43-3316] Signal SIGSEGV received. during elab
@gaurav_ag, does the issue also occur in 2017.3?
Can you submit a test case, enabling for the issue to be investigated locally?
check these ARs
https://www.xilinx.com/support/answers/69251.html
https://www.xilinx.com/support/answers/64809.html
Thanks and Regards
Balkrishan
Hi @gaurav_ag,
If you are using SystemVerilog then check out User Guide 900 (attached) for which features are supported in Simulation.
This may help identify what is causing the elab error.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
