Newbie muhafz
[XSIM 43-3409] Failed to compile generated C file xsim.dir/fourBitCnt_behav/obj/xsim_1.c.
Hi I am using Deepin Linux and I need to use Vivado web pack for my school project
I install the Vivado 2018.3 everything ok but I see this error when I want to see the simulation results
Re: [XSIM 43-3409] Failed to compile generated C file xsim.dir/fourBitCnt_behav/obj/xsim_1.c.
Hi @muhafz,
You are using unsupported OS so you are facing this issue. Please check page 16 of UG973 for supported OS.
Anyhow please check the below thread where one user posted a solution for the similar issue when using an unsupported OS. Please check and see if it helps
https://forums.xilinx.com/t5/Simulation-and-Verification/One-solution-to-error-quot-Failed-to-compile-generated-C-file/td-p/865415
Newbie muhafz
Don't working
I see in the log file this
/tools/Xilinx/Vivado/2018.3/data/../tps/llvm/3.1/lnx64.o/bin/clang -fPIC -c -std=gnu89 -nobuiltininc -nostdinc++ -w -Wl,--unresolved-symbols=ignore-in-object-files -fbracket-depth=1048576 -I/tools/Xilinx/Vivado/2018.3/data/../tps/llvm/3.1/lnx64.o/bin/../lib/clang/3.1/include -fPIC -m64 -I"/tools/Xilinx/Vivado/2018.3/data/xsim/include" "xsim.dir/fourBitCnt_behav/obj/xsim_1.c" -O0 -sim -o "xsim.dir/fourBitCnt_behav/obj/xsim_1.lnx64.o" -DXILINX_SIMULATOR
ERROR: [XSIM 43-3409] Failed to compile generated C file xsim.dir/fourBitCnt_behav/obj/xsim_1.c.
ERROR: [XSIM 43-3915] Encountered a fatal error. Cannot continue. Exiting...
