XSIM Verilog replication operator with zero produces incorrect values
When using replication operator the Vivado simulator produces incorrect values quietly without generating a warning or error.
module test(
    wire [3:0] a = 'b1;
    wire [3:0] b;
    assign b = {a,{0{1'b0}}};
    initial begin
        #1;
        $display("b is %d",b);
    end
endmodule
Vivado Simulator 2018.2
Time resolution is 1 ps
b is  2
Same result I got with 2017.4
Re: XSIM Verilog replication operator with zero produces incorrect values
Hi @ronagyl_adi,
Issue  been reported tp factory.
Sunilkumar
A little late to this thread, however please note that a zero replication count is entirely legal within the language - as long as it appears in a concatenation -as your example does.
The example above should not produce an error nor warning.  The resulting value of variable b should be 4'd1.  So the problem with XSIM is it produces the wrong value.
Mark
