XSim 2019.1 crashes with arrays of -1 downto 0 signals
I'm developing a core where arrays of STD_LOGIC_VECTOR are used.
Some SLV signals have parametric width, so when width=0 these arrays are composed of N elements of SLV(-1 downto 0).
When I try to simulate the core with XSIM, all works fine until I try to add these signals to the waveform window.
On the picture above, if I drag and drop one of the arrays from left to right, XSIM and Vivado crashes and closes.
It seems there's a problem with null SLV, probably ranges are not checked on visualization.
How can I fix this?
Andrea
Re: XSim 2019.1 crashes with arrays of -1 downto 0 signals
Quick thought
you say -1 downto 0, is not 0 greater than -1, so should it be -1 to 0 ?
@drjohnsmith
No
a (-1 downto 0) array is a valid array size - a null (0 length) array. When you parameterise blocks with a width paramter (for example) you can set the WIDTH to 0 and if your declaration is
data : in std_logic_vector(WIDTH-1 downto 0);
Then (-1 downto 0) will result when WIDTH is set to 0 (ie. you want the interface removed).
As a side note, (-1 to 0) would be an illegal range for a std_logic_vector as slv is declared as having a natural range, where the smallest legal index is 0 (this is also the same for signed/unsigned). This is unless the range is a null range, when such indeces are allowed. The fixed_pkg allows -ve indeces to indicate the power of two the bit represents.
Xsim is not alone in crashing with null signals on the waveform. ActiveHDL also did this until a couple years ago.
@andpas.qas
Also note, Synthesis also has problems with null arrays inside records
https://forums.xilinx.com/t5/Synthesis/VHDL-Bug-Report-Vivado-Removes-non-null-port/m-p/850764
edit: This appears to finally be fixed in 2019.2! :)
thanks for noticing me about it.
I encountered indeed a similar problem with records a couple of weeks ago, where again -1:0 ranges have problems.
Maybe it has been fixed in 2019.2 as well... maybe it worths a try...
https://forums.xilinx.com/t5/Simulation-and-Verification/XSim-2019-1-bug-strange-behavior-crash-when-assigning-a-record/td-p/1069406
Anyway: Xilinx SHALL invest some time to fix these basic issues!!
Andrea
