XSim errors while starting behavioral simulation
Xsim (Vivado 2019.1) generates the following error during behavioral simulation of my design. The design contains a 10G ethernet IP using GTH transceivers. The design contains both verilog and vhdl files.
ERROR: [XSIM 43-3241] File /wrk/2019.1/continuous/2019_05_24_2552052/data/secureip/gthe4_channel/gthe4_channel_002.vp, Line Num 22720, Node SIM_VERSION is not annotated.
ERROR: [XSIM 43-4542] Design has hierarchical references, for which we have limited support in mixed language scenarios. You may try to compile using the "-dup_entity_as_module" option for the xelab command.
How to work around those errors?
Re: XSim errors while starting behavioral simulation
anusua.das9@gmail.com,
Is this the 10G Ethernet MAC v15.1 IP core from Xilinx?
If so, the PG072 June 6, 2018 docu has an example_design with this core? Did run a simulation of this example_design to test the IP core before using it in your own design?
FPGA enthusiast!
All PMs will be ignored
It is 10G/25G Ethernet Subsystem (3.0) from Xilinx. I have already built an example design for this, and the simulation runs perfectly fine with the example design.
FPGA used: Zynq Ultrascale+
I'm getting the same error message.  Were you able to find a fix?
