prateekmohan
Xilinx ISE 14.7 Internal Compiler Error
I am trying to run a simulation using Xilinx ISE 14.7 (The FPGA I am synthesizing for is a Spartan 6, so I can't use Vivado) and I am running into a FATAL_ERROR:
FATAL_ERROR:Simulator:CompilerAssert.h:40:1.29 - Internal Compiler Error in file ../src/VlogDecl.cpp at line 1483 For technical support on this issue, please visit http://www.xilinx.com/support.
The line right before this is:
Completed static elaboration
Fuse Memory Usage: 101404 KB
Fuse CPU Usage: 1200 ms
Compiling module memc3_infrastructure_sim(C_MEMCL...
The module that it is referring to (memc3_infrastructure_sim) is actually an empty module - it just has a module declaration. I removed the inner code in hopes it was related to the code inside it but that doesn't seem to be the case either.
Thanks in advance for the help!
Prateek
prateekmohan
I'm closing this ticket - I was able to compile by just creating a simulation model of this block outside the Verilog DUT.
Prateek
prateekmohan
Prateek
