mariem_@fsm.12-34
Xilinx logicore IP
I am a biginner in using Xilinx logicore IP. I use vivado IDE , I want to write a testbensh to test these Xilinx IPs.
Is there tutorials or examples to follow to do my one?
Regars
dpaul24
Your Q is generic, so will be my answer.
Basically Xilinx provides test-benches for many of the complex IPs.
After generating an IP, in the Sources Window, you can right-click and generate the "example design" for that IP. It would be a simple application of that IP along with test-bench.
For IP that don't have an example design........well what can say, study the IP interfaces, study the IP documentation and simulate its IPs/OPs from your own test-bench. Basically you have to understand fully what an IP is doing in order to write a good test-bench for it.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
prathikm
Hi mariem_@fsm.12-34,
As @dpaul24 suggested, many Xilinx IP deliver an example design project. The example design project consists of top-level logic and constraints that interact with the created IP customization. These example designs typically come with an example test bench that helps simulate the design.
Open IP catalog and generate the IP. Once it is generated right click on the IP and select "open IP example design".
Thanks & Regards,
Prathik
Helpful answer -> Give Kudos
