ZYNQMP ELF simulation
Hi All,
Is it possible to include the ELF in vivado simulation for a ZCU102 (zynq ultrascale+) design?
I have seem some posts that talks about such a simulation when microblaze is used. If ARM in PS is used then can I still run a simulation such that the c code that would have been executed on hw, also somehow gets executed by ps during simulation?
When I tried associate elf file after adding it to simulation sources, it says -
"No usee accessible processors found for ELF file association"
If not to be simulated this way, is there any other way?
Chinmaya
Vervesemi Microelectronics
Re: ZYNQMP ELF simulation
Hi @cdvervesemi ,
This Feature is not supported. you can simulate a Zynq MPSoC with ELF. Zynq have Hardcore Processor and this is not supported for simulation with Elf.
Best Regards,
Srikanth
All these seem to be about the case when a microblaze is in PL.
Is it possible to run vivado simulation (without involving board) such that the c code also becomes part of simulation.
One work-around I am using now is adding a new AXI VIP master and translate c codes that would actually run on PS to AXI transactions in simulation.
Chinmaya
Hi @cdvervesemi ,
Best Regards,
Srikanth
