sbagga89
Zynq MPSOC ZCU102
I hope someone can help. I have been pretty frustrated with this issue. I am new to vivado block design.
i used an example project walk through from Xilinix that uses Zynz Ultrascale+ MPSoC with Axi SmartConnect to a Axi Bram controller that is tied to a dual port block ram.
I was able to verify writes using Zync_VIP commands as a test bench in system verilog simulation. However i tried to add a custom RTL module. This module is tied to port B of dual port ram. I am unable to see the signals of this custom RTL module in simulation scope. The module shows up in design sources and is in the block design.
I first thought the block was being optimized out so i turned of optimization using xelab -O0 arguments.
i hope this is enough information for you to help. Thank you!
raj
@sbagga89
Is it possible to post a screenshot of the vivado block design ?
