Observer kuldipspx
Zynq VIP AR67207
The link to the AR67207 in DS940 is incorrect. Please provide the correct link to the Zynq VIP example design.
thanks
kuldip
Re: Zynq VIP AR67207
Hi @kuldipspx,
You may want to look at PG267 (link) instead. It is more complete and has the correct AR (AR#68234).
I will check if the DS940 was supposed to be published (for example, it cannot be found on DocNav)
Florent
Florent
Observer kuldipspx
Please provide Zynq VIP based example design. I want to update my simulation testbench from Zynq BFM to Zynq VIP.
thanks
kuldip
Hi @kuldipspx,
This is in the AR -> link
Florent
Florent
Visitor lishixing
Have you solved your problem?
Visitor lishixing
I also want to update my simulation testbench from Zynq BFM to Zynq VIP.Can you give me a testbench example?
Hi @lishixing,
1. If you have an issue, you should create a new post on the forums.
2. If you need an example to use the VIP: add the VIP to a BD. In the source window, find the VIP, right click on it > generate example desing. You will have example test benches.
Florent
Florent
Visitor lishixing
Hi@florentw
1.My problem is similar to his.
2.I want use "Zynq-7000 All Programmable SoC Verification IP v1.0" this ip.I hope to use the function of the figure below.The Zynq-7000 VIP will automatically be delivered as part of the Zynq Processing System block simulation source. So,I can not find a testbench example.
Observer mferraro
I also have the same request.
Florent > you are providing links and references to the AXI VIP.   This question is about ZYNQ VIP.  These are two different simulation models.  With the Zynq VIP; the 'right click generate example design is not available'
lishixing > you can get example test bench by going
File -> Open Example Project > Base Zynq
Then look at zynq_tb.v :
tb.zynq_sys.base_zynq_i.processing_system7_0.inst.fpga_soft_reset(32'h1);
tb.zynq_sys.base_zynq_i.processing_system7_0.inst.fpga_soft_reset(32'h0);
//This drives the LEDs on the GPIO output
tb.zynq_sys.base_zynq_i.processing_system7_0.inst.write_data(32'h41200000,4, 32'hFFFFFFFF, resp);
$display ("LEDs are toggled, observe the waveform");
//Write into the BRAM through GP0 and read back
tb.zynq_sys.base_zynq_i.processing_system7_0.inst.write_data(32'h40000000,4, 32'hDEADBEEF, resp);
tb.zynq_sys.base_zynq_i.processing_system7_0.inst.read_data(32'h40000000,4,read_data,resp);
$display ("%t, running the testbench, data read from BRAM was 32'h%x",$time, read_data);
HI @mferraro,
You are right I have mixed between the AXI VIP and the zynq VIP. Thank you for sharing a way to have a test bench.
The correct AR is AR#69031
Florent
Florent
Visitor hypze
       Using this example design,add some code to zynq_tb.v.I want to read data from "img.txt",through the HP ports. No data obtain.
       //Reset the PL
        /////    zynq  vip
        tb.zynq_sys.base_zynq_i.processing_system7_0.inst.set_slave_profile("S_AXI_HP0",2'b00);
        tb.zynq_sys.base_zynq_i.processing_system7_0.inst.set_channel_level_info("ALL",0);
        tb.zynq_sys.base_zynq_i.processing_system7_0.inst.set_function_level_info("ALL",0);
        tb.zynq_sys.base_zynq_i.processing_system7_0.inst.set_debug_level_info(0);
        tb.zynq_sys.base_zynq_i.processing_system7_0.inst.pre_load_mem_from_file("img.txt",32'h0100_0000,102400);
Observer mferraro
Visitor seiranp
Hi Florent , is any way to disable/enable messages into TCL window from ZYNQ VIP API ?
HI @seiranp,
Our Community Help has a tip that might help you : Tip: If the message is older than 6-12 months, please post a new message rather than adding to the existing thread. Your inquiry will have a better chance of being picked up by an expert if it is a new topic.
https://forums.xilinx.com/t5/help/faqpage/faq-category-id/posting#posting
I would suggest you create a new topic on the appropriate board. This is a different question, I will not reply to this topic.
Florent
