Voyager
Voyager
ZynqMP - Debugging AXI DMA while user application is running on PS
I would like to debug AXI DMA behaviour and for this purpose I placed an ILA on its S2MM AXI interface. The AXI DMA is controlled using an uio userspace application from Linux.
To start the ILA debugging I have to program the device from the Vivado Hardware Manager, but this hangs the whole Linux system into the PS so I am unable to perform debug.
Am i missing something ?
What is the proper wat to debug AXI DMA in this case ?
s.
Re: ZynqMP - Debugging AXI DMA while user application is running on PS
Hi @simozz
If you are using MPSoC, this AR may be the solution.
AR#69143 Zynq UltraScale+ MPSoC: Connecting XSDB to Linux CPU idle
Ka2ki
Hi @simozz
Ka2ki
Voyager
Voyager
Thanks, @katsuki.
s.
