annoying problem about modelsim SE libraries with ISE
Dear all,
I am having annoying trouble with the Modelsim libraries.
1) I compiled all libraries with "Simulation Library Compilation Wizard" I got 34 errors for edk, and one more error for another thing, I forgot to take the snapshot and post here... Is it really worrying thing to be
2) In Process properties of Simulate behavioural model -> what to put in "compiled Library directory"... Some time when I put the working directory "C:\Xilinx\13.2\ISE_DS\ISE" it works and some time does not... Then I have to make it default i.e. "$XILINX\<language>\<simulator>" so sometime it works with it and some time not then I again change to previous and it start working...
3) what does[B] $XILINX\<language>\<simulator>[/B] means...! please elaborate...
Sorry for being so verbose... I have one more strange problem but I will post it later... :-)
Many Thanks in advance...
Shan
Historian
Historian
Re: annoying problem about modelsim SE libraries with ISE
@sraza wrote:
Dear all,
Shan
You have to substitute actual values for <language> and <simulator>. Language is obviously VHDL or Verilog, and simulator is something that indicates what simulation tool is actually being used.
What is the SE version you are trying to use with ISE 13.2?
Debraj
