awkward result in post implementation timing simulation
I design a module for rgbtogrey.  When i start  post implementation timing simulation,I get the following result.(gryodata)
Everything was seamless until post implementation timing simulation, but here I came across something like this.
I would be very happy if someone could help me with this subject.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use work.types.all;
entity rgb2grey is
                        Port (
                               clk      : in std_logic;
                               active_i : in std_logic;
                               active_o : out std_logic;
                               rgb_in   : in  std_logic_vector(23 downto 0);
                               gry_o    : out std_logic_vector(7 downto 0)
end rgb2grey;
architecture Behavioral of rgb2grey is
signal active,active2,active3,active4: std_logic:='0';
--signal temp_gry,temp_gry2,temp_gry3,temp_gry4 : std_logic_vector(7 downto 0):=(others=>'0');
signal temp_gry,temp_gry2,temp_gry3,temp_gry4,tempy_reg,temp_son : integer:=0;
  --temp_gry<= std_logic_vector(to_unsigned((to_integer(unsigned(rgb_in(7 downto 0))) + to_integer(unsigned(rgb_in(15 downto 8))) + to_integer(unsigned(rgb_in(23 downto 16))))/3,8));
BEGIN
    process(clk)
    begin
        if rising_edge(clk) then
            if active_i='1' then
                temp_gry<= to_integer(unsigned(rgb_in(7 downto 0)))/3;
                temp_gry2<=to_integer(unsigned(rgb_in(15 downto 8)))/3;
                temp_gry3<=to_integer(unsigned(rgb_in(23 downto 16)))/3;
                active<='1';
            else
                active<='0';
            end if;
            temp_gry4<=temp_gry+temp_gry2;
            tempy_reg<=temp_gry3;
            temp_son<=temp_gry4+tempy_reg;
            gry_o<=std_logic_vector(to_unsigned(temp_son,8));
            active2<=active;
            active3<=active2;
            active4<=active3;
            end if;
    end process;
--        gry_o<=temp_gry3;
        active_o<=active4;
end Behavioral;
Scholar richardhead
Re: awkward result in post implementation timing simulation
These are glitches, and are expected. The path length of each bit on a bus will vary, and so each bit changes at a different time. As long as the design meets the timing specs (specifically the setup/hold time) then there is no problem. What you see are the bits all changing at different times after the clock edge (the setup time) and they are ready well before the next edge (hold time).
these two photos maybe a little more revealing about my problem.tuhaf2.JPGtuhag.JPG
Scholar richardhead
