haint161308
axi_uart16550_v2_0_vh_rfs.vhd(3390): (vcom-1484) Unknown formal identifier "SIM_DEVICE".
Hi Everyone, I have a problem when I bring a project from vivado 2018.1 to vivado 2019.1. KIT I using is Kintex7 KC705. When I open the project at vivado 2019.1 I received a message upgrade IP. I have upgraded it. after that, I generate a block design. But I don't know why when I run behavior simulation at vivado 2018.1 not have errors. But when I run behavior simulation at vivado 2019.1 I have error "axi_uart16550_v2_0_vh_rfs.vhd(3390): (vcom-1484) Unknown formal identifier "SIM_DEVICE" ".
Everyone you can help me resolve this problem. I really thanks you for your help
haint161308
I resolved this problem. Due to I upgrade from vivado 2018 to vivado 2019 but I still use a library of questa2018. If you also have a error like me you can compile library simulation in Vivado. You can create a new lib for simulation. https://www.xilinx.com/support/answers/64083.html
haint161308
