Observer bondylep
axis fifo simulation s_axis_tready is alwasys low
in my design ip instantiated a axis fifo,  simulation ok, s_axis_tready will high when aresetn released, but in my top project
instantiated my IP, then simulation  s_axis_tready will always low. which difference is that ,the aresetn is from processor reset module which will not reset when simulation start which will have simulation intialize problem, so i force the reset assert, and then released.
I can not see any internal singal, i cannot debug it at all. is this any way to probe interanal singal?
I also simlate the example fifo IP, it is Ok, so i am much confused by it.
I used the *funsim.v to substitue it to simulate, it is ok.
Observer bondylep
Re: axis fifo simulation s_axis_tready is alwasys low
it may be the cause that I force the reset singal, if i does not force, it is OK, but the root cause will not be known.
Observer bondylep
I force the aresetn low again and high, the s_axis_ready go high, I have long time aresetn low at start time of simulation.  there is enough time to reset it,  why it need reset twice?
Observer bondylep
