Visitor amol_aeva
clock must be initialized to 0 when using xpm_fifo
I spend more than a day trying to debug this so I thought I'd add this here in the hopes that someone else will find it useful.
I am using an XPM_FIFO in my design configured in async mode. The wr_clk being driven from my testbench was created like this:
  logic wr_clk;
  initial begin
    wr_clk = 1'b1;
  end
  // 250MHz
  always #2 wr_clk = ~wr_clk;
When I run the simulation, the wr_rst_busy output from the fifo never goes low! After much trial and error, I found out that initializing the clock to 0 and not 1 makes everything work! Go figure. If anyone knows the logic behind this please chime in. This may be the case with other IP as well.
initial begin
  wr_clk = 1'b0; // MUST BE 0!
end
Scholar jmcclusk
Re: clock must be initialized to 0 when using xpm_fifo
Can you post a test case showing this behavior?   It will help to diagnose (and fix) this behavior.
Hi @amol_aeva
I have seen a similar issue in the past when using vivado XSIM. The design works fine when using Questa simulator. I have filed CR 989523 to get this fixed.
Deepika.
