compile_simlib error Failed to find the simulator executable
   I've an issue compiling lib for Questa (same result with Modelsim) in Vivado 2017.4, the error is:
ERROR: [Vivado 12-3754] Failed to find the 'questasim' simulator executable. Make sure to set the 'questasim' installation environment and retry this command to compile the libraries for this simulator. For more information on tool setup refer 'questasim' user guide.
Library compilation for 'questasim' ignored.
I've already set
Tools-Options-3rd Party Simulators - exe location
c:/programs/questasim64_10.6c/win64
Tools-Compile Simulation Library
C:/programs/questasim64_10.6c/xilinx_test  as lib destination
c:/programs/questasim64_10.6c/win64        as sim exe path
The command line is
compile_simlib -simulator questa -simulator_exec_path {c:/programs/questasim64_10.6g/win64} -family kintexuplus -language all -library all -dir {C:/programs/questasim64_10.6c/xilinx_test} -force -verbose
The output is
compile_simlib -simulator questa -simulator_exec_path {c:/programs/questasim64_10.6g/win64} -family kintexuplus -language all -library all -dir {C:/programs/questasim64_10.6g/xilinx_test} -force -verbose
INFO: [Vivado 12-4753] Extracting data from the IP repository...(this may take a while, please wait)...
INFO: [setup_ip_static_library-Tcl-23] Data extracted from repository. Inspected 400 IP libraries.
setup_ip_static_library: Time (s): cpu = 00:01:31 ; elapsed = 00:01:52 . Memory (MB): peak = 1127.676 ; gain = 330.406
> Current directory :- 'C:/Users/scandrog/AppData/Roaming/Xilinx/Vivado'
> Library data paths:- 'C:\programs\Xilinx\Vivado\2017.4\data'
> Device family(s) :- 'kintexuplus'
> Library(s) :- 'simprim, unisim'
> Language(s) :- 'vhdl, verilog'
> Compilation mode :- '64-bit'
INFO: [Vivado 12-5496] Finding simulator executables and checking version...
> executing 'c:\programs\questasim64_10.6g\win64/vcom.exe -version -64'...
output file: '.cxl.questasim.version'
return code: '0'
compile_simlib: Time (s): cpu = 00:01:31 ; elapsed = 00:01:54 . Memory (MB): peak = 1127.676 ; gain = 330.406
ERROR: [Common 17-39] 'compile_simlib' failed due to earlier errors.
1) C:\Users\scandrog\AppData\Roaming\Xilinx\Vivado\.cxl.questasim.version
remains empty
On machine where it works, file is filled with "QuestaSim-64 vcom 10.6c ..."
2) If I manually type in Vivado tcl console
exec c:/programs/questasim64_10.6c/win64/vcom -version
A DOS windows pops up and then closes, so it looks vivado cannot catch the commans ouput.
Any clue?
回复: compile_simlib error Failed to find the simulator executable
ok IT installed a monitoring software that blocks the tool.
A magic "Run elevated" button fixed.
Another user had the same problem as depicted here:
https://forums.xilinx.com/t5/Simulation-and-Verification/ERROR-Vivado-12-3754-Failed-to-find-the-questasim-simulator/m-p/1071721
From your command,
Is it a typo? If you're using 10.6c, what is returned if you run this from command line?
Hi Graces,
   it's not a matter of Questa version, I have the same failure with Questa 10.6c.
I haven't solved yet.
When Vivado fails compiling the lib, it produces an empy ".cxl.questasim.version".
On "working" machines instead, Vivado populate ".cxl.questasim.version" with string
QuestaSim-64 vcom 10.6c Compiler 2017.07 Jul 26 2017
So Vivado is able to locate the Questa executable but I cannot identify the Questa version since the .cxl.questasim.version is empy.
Any clue on why?
Machines with this issue becomes unusable.
Please help.
same error here with vivado 2019.2 + questa 2019.2 on a win10 machine.
The .cxl.questasim.version is empty.
Logs attached
compile_simlib -simulator questa -simulator_exec_path {D:/programs/questasim64_2019.2/win64} -family kintexu -family kintexuplus -language all -library all -dir {D:/programs/questasim64_2019.2/xilinx/2019.2} -force -verbose
INFO: [setup_ip_static_library-Tcl-23] Data extracted from repository. Inspected 556 IP libraries.
setup_ip_static_library: Time (s): cpu = 00:01:20 ; elapsed = 00:09:02 . Memory (MB): peak = 1073.137 ; gain = 55.027
> Current directory :- 'C:/Users/maggione/AppData/Roaming/Xilinx/Vivado/pippo1'
> Library data paths:- 'D:\programs\Xilinx\Vivado\2019.2\data'
'D:\programs\Xilinx\Vivado\2019.2\ids_lite\ISE'
> Device family(s) :- 'kintexu, kintexuplus'
> executing 'D:\programs\questasim64_2019.2\win64/vcom.exe -version -64'...
> forking 'D:\programs\questasim64_2019.2\win64/vcom.exe -version -64'
return code: '0'
Time taken: 0 mins (3 secs)
compile_simlib: Time (s): cpu = 00:01:20 ; elapsed = 00:09:07 . Memory (MB): peak = 1073.137 ; gain = 55.027
As mentioned, then what does it return if you run "<full path>\vcom -version" from command line prompt?
That is supposed to work. Can you attach the compile_simlib.log for a look?
