kynthia9
compile_simlib error again, after INCISIV version fix
still have the error like :
compile_simlib -simulator ncsim -directory /user/nak/work/xlib/
Compiling libraries for 'ies' in '/user/nak/work/xlib/'
--> Compiling 'verilog.secureip' library...
> Source Library = '/vl/edatools/extern/Xilinx/Vivado/2014.3/data/secureip'
> Compiled Path = '/user/nak/work/xlib//secureip'
> Log File = '/user/nak/work/xlib//secureip/.cxl.verilog.secureip.secureip.lin64.log'
--> Compiling 'verilog.secureip:verilog.axi_bfm' library...
> Source Library = '/vl/edatools/extern/Xilinx/Vivado/2014.3/data/secureip/axi_bfm'
> Log File = '/user/nak/work/xlib//secureip/.cxl.verilog.axi_bfm.secureip.lin64.log'
compile_simlib[verilog.secureip:verilog.axi_bfm]: 0 error(s), 7 warning(s)
compile_simlib[verilog.secureip]: 0 error(s), 14 warning(s), 25.00 % complete
--> Compiling 'vhdl.unisim' library...
> Source Library = '/vl/edatools/extern/Xilinx/Vivado/2014.3/data/vhdl/src/unisims'
> Compiled Path = '/user/nak/work/xlib//unisim'
> Log File = '/user/nak/work/xlib//unisim/.cxl.vhdl.unisim.unisim.lin64.log'
--> Compiling 'vhdl.unisim:vhdl.unimacro' library...
> Source Library = '/vl/edatools/extern/Xilinx/Vivado/2014.3/data/vhdl/src/unimacro'
> Compiled Path = '/user/nak/work/xlib//unimacro'
> Log File = '/user/nak/work/xlib//unimacro/.cxl.vhdl.unimacro.unimacro.lin64.log'
compile_simlib[vhdl.unisim:vhdl.unimacro]: 1 error(s), 10 warning(s)
INFO: Please refer to the messages between 'BEGIN_COMPILATION_MESSAGES(ies:vhdl:unimacro)' and 'END_COMPILATION_MESSAGES(ies:vhdl:unimacro)' in the log file compile_simlib.log for details of compilation error(s).
--> Compiling 'vhdl.unisim:vhdl.unifast' library...
> Source Library = '/vl/edatools/extern/Xilinx/Vivado/2014.3/data/vhdl/src/unifast'
> Compiled Path = '/user/nak/work/xlib//unifast'
> Log File = '/user/nak/work/xlib//unifast/.cxl.vhdl.unifast.unifast.lin64.log'
compile_simlib[vhdl.unisim:vhdl.unifast]: 1 error(s), 8 warning(s)
INFO: Please refer to the messages between 'BEGIN_COMPILATION_MESSAGES(ies:vhdl:unifast)' and 'END_COMPILATION_MESSAGES(ies:vhdl:unifast)' in the log file compile_simlib.log for details of compilation error(s).
compile_simlib[vhdl.unisim]: 3 error(s), 30 warning(s), 50.00 % complete
Please refer to the messages between 'BEGIN_COMPILATION_MESSAGES(ies:vhdl:unisim)' and 'END_COMPILATION_MESSAGES(ies:vhdl:unisim)' in the log file compile_simlib.log for details of compilation error(s).
--> Compiling 'verilog.unisim' library...
> Source Library = '/vl/edatools/extern/Xilinx/Vivado/2014.3/data/verilog/src'
> Compiled Path = '/user/nak/work/xlib//unisims_ver'
> Log File = '/user/nak/work/xlib//unisims_ver/.cxl.verilog.unisim.unisims_ver.lin64.log'
--> Compiling 'verilog.unisim:verilog.unimacro' library...
> Source Library = '/vl/edatools/extern/Xilinx/Vivado/2014.3/data/verilog/src/unimacro'
> Compiled Path = '/user/nak/work/xlib//unimacro_ver'
> Log File = '/user/nak/work/xlib//unimacro_ver/.cxl.verilog.unimacro.unimacro_ver.lin64.log'
compile_simlib[verilog.unisim:verilog.unimacro]: 0 error(s), 2 warning(s)
--> Compiling 'verilog.unisim:verilog.unifast' library...
> Source Library = '/vl/edatools/extern/Xilinx/Vivado/2014.3/data/verilog/src/unifast'
> Compiled Path = '/user/nak/work/xlib//unifast_ver'
> Log File = '/user/nak/work/xlib//unifast_ver/.cxl.verilog.unifast.unifast_ver.lin64.log'
compile_simlib[verilog.unisim:verilog.unifast]: 0 error(s), 1 warning(s)
compile_simlib[verilog.unisim]: 0 error(s), 6 warning(s), 75.00 % complete
--> Compiling 'verilog.simprim' library...
> Source Library = '/vl/edatools/extern/Xilinx/Vivado/2014.3/data/verilog/src/unisims'
> Compiled Path = '/user/nak/work/xlib//simprims_ver'
> Log File = '/user/nak/work/xlib//simprims_ver/.cxl.verilog.simprim.simprims_ver.lin64.log'
compile_simlib[verilog.simprim]: 0 error(s), 0 warning(s), 100.00 % complete
Copying setup file 'cds.lib' to '/user/nak/work/xlib//cds.lib' ...
Copying setup file 'hdl.var' to '/user/nak/work/xlib//hdl.var' ...
* COMPILATION SUMMARY *
* Simulator used: ies *
* Compiled on: Thu Oct 30 12:07:22 2014 *
* Library | Lang | Mapped Name(s) | Err#(s) | Warn#(s) *
* secureip | verilog | secureip | 0 | 14 *
* axi_bfm | verilog | secureip | 0 | 7 *
* unisim | vhdl | unisim | 3 | 30 *
* unimacro | vhdl | unimacro | 1 | 10 *
* unifast | vhdl | unifast | 1 | 8 *
* unisim | verilog | unisims_ver | 0 | 6 *
* unimacro | verilog | unimacro_ver | 0 | 2 *
* unifast | verilog | unifast_ver | 0 | 1 *
* simprim | verilog | simprims_ver | 0 | 0 *
ERROR: [Vivado 12-3591] compile_simlib failed to compile for ies with 5 errors.
compile_simlib: Time (s): cpu = 00:02:50 ; elapsed = 00:03:28 . Memory (MB): peak = 8446.527 ; gain = 0.008 ; free physical = 124063 ; free virtual = 230020
ERROR: [Common 17-39] 'compile_simlib' failed due to earlier errors.
log file:
ncvhdl(64): 14.10-g041: (c) Copyright 1995-2014 Cadence Design Systems, DEBUG
DEFINE unimacro /user/nak/work/compxlib//unimacro
ncvhdl: *W,DLCPTH (./cds.lib,1): cds.lib Invalid path '/user/nak/work/compxlib/unimacro' (cds.lib command ignored).
DEFINE unifast /user/nak/work/compxlib//unifast
ncvhdl: *W,DLCPTH (./cds.lib,2): cds.lib Invalid path '/user/nak/work/compxlib/unifast' (cds.lib command ignored).
DEFINE unisims_ver /user/nak/work/compxlib//unisims_ver
ncvhdl: *W,DLCPTH (./cds.lib,3): cds.lib Invalid path '/user/nak/work/compxlib/unisims_ver' (cds.lib command ignored).
DEFINE unimacro_ver /user/nak/work/compxlib//unimacro_ver
ncvhdl: *W,DLCPTH (./cds.lib,4): cds.lib Invalid path '/user/nak/work/compxlib/unimacro_ver' (cds.lib command ignored).
DEFINE unifast_ver /user/nak/work/compxlib//unifast_ver
ncvhdl: *W,DLCPTH (./cds.lib,5): cds.lib Invalid path '/user/nak/work/compxlib/unifast_ver' (cds.lib command ignored).
DEFINE simprims_ver /user/nak/work/compxlib//simprims_ver
ncvhdl: *W,DLCPTH (./cds.lib,6): cds.lib Invalid path '/user/nak/work/compxlib/simprims_ver' (cds.lib command ignored).
ncvhdl_p: *W,DLCPTH (./cds.lib,1): cds.lib Invalid path '/user/nak/work/compxlib/unimacro' (cds.lib command ignored).
ncvhdl_p: *W,DLCPTH (./cds.lib,2): cds.lib Invalid path '/user/nak/work/compxlib/unifast' (cds.lib command ignored).
ncvhdl_p: *W,DLCPTH (./cds.lib,3): cds.lib Invalid path '/user/nak/work/compxlib/unisims_ver' (cds.lib command ignored).
ncvhdl_p: *W,DLCPTH (./cds.lib,4): cds.lib Invalid path '/user/nak/work/compxlib/unimacro_ver' (cds.lib command ignored).
ncvhdl_p: *W,DLCPTH (./cds.lib,5): cds.lib Invalid path '/user/nak/work/compxlib/unifast_ver' (cds.lib command ignored).
ncvhdl_p: *W,DLCPTH (./cds.lib,6): cds.lib Invalid path '/user/nak/work/compxlib/simprims_ver' (cds.lib command ignored).
ncvhdl_p: *F,NOLSTD: logical library name STD must be mapped to a design library [11.2].
INCISIV 14.1
PATCH g041
any other solve?
vuppala
Try these steps to resolve the issue.
1. Point the first line of cds.lib file (located in '/user/nak/work/xlib/ directory) to the location of cds.lib file of ius installation
i.e., INCLUDE /vl/edatools/tools.lnx86/inca/files/cds.lib
2. Next navigate to /user/nak/work/xlib/unisim and run .cxl.vhdl.unisim.unisim.lin64.cmd
3. If it says permission denied, change the file permissions using the command: chmod +x '/user/nak/work/xlib/unisim and then run.
Repeat 2 and 3 steps for unifast and unimacro as well.
Note: Do not run compile_simlib after following these steps. It will override above edited files.
Vinay
vijayak
Can you please try with Cadence Incisive Enterprise
Simulator (IES) (13.20.005) as this is the supported one with Vivado 2014.3
Thanks,Vijay
kynthia9
still the same error
vijayak
Can you please use the following command see if this helps.
-simulator ncsim is incorrect. You need to use ies as keyword
compile_simlib -language all -dir {/a/b/c} -simulator ies -simulator_exec_path {<simulator_installation_path>} -library all -family all
Thanks,Vijay
kynthia9
the same error
kynthia9
compile_simlib -language all -dir {/user/nak/work/xlib} -simulator ies -simulator_exec_path {/vl/edatools/bin} -library all -family all
Compiling libraries for 'ies' in '/user/nak/work/xlib'
Library verilog.secureip:verilog.axi_bfm will not be compiled, because precompiled library info is up to date.
Library verilog.secureip will not be compiled, because precompiled library info is up to date.
compile_simlib[verilog.secureip]: 0 error(s), 0 warning(s), 25.00 % complete
Library vhdl.unisim will be compiled, because precompiled library info is stale.
> Compiled Path = '/user/nak/work/xlib/unisim'
> Log File = '/user/nak/work/xlib/unisim/.cxl.vhdl.unisim.unisim.lin64.log'
Library vhdl.unisim:vhdl.unimacro will be compiled, because precompiled library info is stale.
> Compiled Path = '/user/nak/work/xlib/unimacro'
> Log File = '/user/nak/work/xlib/unimacro/.cxl.vhdl.unimacro.unimacro.lin64.log'
compile_simlib[vhdl.unisim:vhdl.unimacro]: 1 error(s), 0 warning(s)
Library vhdl.unisim:vhdl.unifast will be compiled, because precompiled library info is stale.
> Compiled Path = '/user/nak/work/xlib/unifast'
> Log File = '/user/nak/work/xlib/unifast/.cxl.vhdl.unifast.unifast.lin64.log'
compile_simlib[vhdl.unisim:vhdl.unifast]: 1 error(s), 0 warning(s)
compile_simlib[vhdl.unisim]: 3 error(s), 0 warning(s), 50.00 % complete
Library verilog.unisim:verilog.unimacro will not be compiled, because precompiled library info is up to date.
Library verilog.unisim:verilog.unifast will not be compiled, because precompiled library info is up to date.
Library verilog.unisim will not be compiled, because precompiled library info is up to date.
compile_simlib[verilog.unisim]: 0 error(s), 0 warning(s), 75.00 % complete
Library verilog.simprim will not be compiled, because precompiled library info is up to date.
Copying setup file 'cds.lib' to '/user/nak/work/xlib/cds.lib' ...
* Compiled on: Fri Oct 31 15:50:36 2014 *
* unisim | vhdl | unisim | 3 | 0 *
* unimacro | vhdl | unimacro | 1 | 0 *
* unifast | vhdl | unifast | 1 | 0 *
vuppala
Attach compile_simlib.log file here.
Also which version of cadence incisive simulator are you using?
Vinay
kynthia9
INCISIV 13.20, PATCH 005
I have ever tried INCISIV 14.1 g041 the same error.
vuppala
Vinay
kynthia9
yes, it works, but nee to edit .cmd file to point cds.lib and hdl.var to upper level where cds.lib and hds.var existed.
wooki21
Thank you.
I also had same problerm and resolved this.
But I don't know what is the root cause.
jadeanderson
I have tried this but I keep getting the same error.
ncvhdl: *F,DULEXE: cannot execute the VHDL analyzer (ncvhdl_p).
Any workaround for this?
* Compiled on: Mon Mar 23 13:49:20 2015 *
* Library | Language | Mapped Library Name | Error(s) | Warning(s) *
* secureip | verilog | secureip | 0 | 0 *
* axi_bfm | verilog | secureip | 0 | 0 *
compile_simlib: Time (s): cpu = 00:01:30 ; elapsed = 00:01:56 . Memory (MB): peak = 810.590 ; gain = 6.090 ; free physical = 26023 ; free virtual = 216884
brendanlynskey
I'm seeing the same problem with Vivado 2015.2.
Do you have a fix for this?
 - Bren
