compile_simlib failed to compile for active_hdl with <number> errors
Any idea how to fix this?
TCL Console output:
start_guicompile_simlib -force -language vhdl -dir {<MY_PATH>.cache/compile_simlib} -simulator active_hdl -simulator_exec_path {C:/Aldec/Active-HDL 10.1/BIN} -library all -family  zynq
Compiling libraries for 'active_hdl' simulator in '<MY_PATH>.cache\compile_simlib'
ALIB: Library `secureip' attached.
secureip = <MY_PATH>.cache\compile_simlib\secureip\secureip.lib
--> Compiling 'verilog.secureip' library...
> Source Library = 'C:\Xilinx\Vivado\2015.4\data/secureip'
> Compiled Path  = '<MY_PATH>.cache\compile_simlib/secureip'
ERROR: [Common 17-180] Spawn failed: No error
> Log File = '<MY_PATH>.cache\compile_simlib/secureip/.cxl.verilog.secureip.secureip.nt64.log'
--> Compiling 'verilog.secureip:verilog.axi_bfm' library...
> Source Library = 'C:\Xilinx\Vivado\2015.4\data/secureip/axi_bfm'
> Log File = '<MY_PATH>.cache\compile_simlib/secureip/.cxl.verilog.axi_bfm.secureip.nt64.log'
compile_simlib[verilog.secureip:verilog.axi_bfm]: 0 error(s), 9 warning(s)
compile_simlib[verilog.secureip]: 1 error(s), 31 warning(s), 50.00 % complete
Please refer to the messages between 'BEGIN_COMPILATION_MESSAGES(active_hdl:verilog:secureip)' and 'END_COMPILATION_MESSAGES(active_hdl:verilog:secureip)' in the log file compile_simlib.log for details of compilation error(s).
ALIB: Library `unisim' attached.
unisim = <MY_PATH>.cache\compile_simlib\unisim\unisim.lib
--> Compiling 'vhdl.unisim' library...
> Source Library = 'C:\Xilinx\Vivado\2015.4\data/vhdl/src/unisims'
> Compiled Path = '<MY_PATH>.cache\compile_simlib/unisim'
> Log File = '<MY_PATH>.cache\compile_simlib/unisim/.cxl.vhdl.unisim.unisim.nt64.log'
ALIB: Library `unimacro' attached.
unimacro = <MY_PATH>.cache\compile_simlib\unimacro\unimacro.lib
--> Compiling 'vhdl.unisim:vhdl.unimacro' library...
> Source Library = 'C:\Xilinx\Vivado\2015.4\data/vhdl/src/unimacro'
> Compiled Path = '<MY_PATH>.cache\compile_simlib/unimacro'
> Log File = '<MY_PATH>.cache\compile_simlib/unimacro/.cxl.vhdl.unimacro.unimacro.nt64.log'
compile_simlib[vhdl.unisim:vhdl.unimacro]: 1 error(s), 1 warning(s)
INFO: Please refer to the messages between 'BEGIN_COMPILATION_MESSAGES(active_hdl:vhdl:unimacro)' and 'END_COMPILATION_MESSAGES(active_hdl:vhdl:unimacro)' in the log file compile_simlib.log for details of compilation error(s).
ALIB: Library `unifast' attached.
unifast = <MY_PATH>.cache\compile_simlib\unifast\unifast.lib
--> Compiling 'vhdl.unisim:vhdl.unifast' library...
> Source Library = 'C:\Xilinx\Vivado\2015.4\data/vhdl/src/unifast'
> Compiled Path = '<MY_PATH>.cache\compile_simlib/unifast'
> Log File = '<MY_PATH>.cache\compile_simlib/unifast/.cxl.vhdl.unifast.unifast.nt64.log'
compile_simlib[vhdl.unisim:vhdl.unifast]: 1 error(s), 1 warning(s)
INFO: Please refer to the messages between 'BEGIN_COMPILATION_MESSAGES(active_hdl:vhdl:unifast)' and 'END_COMPILATION_MESSAGES(active_hdl:vhdl:unifast)' in the log file compile_simlib.log for details of compilation error(s).
compile_simlib[vhdl.unisim]: 3 error(s), 3 warning(s), 100.00 % complete
Please refer to the messages between 'BEGIN_COMPILATION_MESSAGES(active_hdl:vhdl:unisim)' and 'END_COMPILATION_MESSAGES(active_hdl:vhdl:unisim)' in the log file compile_simlib.log for details of compilation error(s).
* COMPILATION SUMMARY *
* Simulator used: active_hdl *
* Compiled on: Fri Feb 16 08:08:49 2018 *
* Library | Language | Mapped Library Name | Error(s) | Warning(s) *
* secureip | verilog | secureip | 1 | 31 *
* axi_bfm | verilog | secureip | 0 | 9 *
* unisim | vhdl | unisim | 3 | 3 *
* unimacro | vhdl | unimacro | 1 | 1 *
* unifast | vhdl | unifast | 1 | 1 *
ERROR: [Vivado 12-3591] compile_simlib failed to compile for active_hdl with 6 errors.
compile_simlib: Time (s): cpu = 00:00:01 ; elapsed = 00:00:18 . Memory (MB): peak = 590.871 ; gain = 9.621
ERROR: [Common 17-39] 'compile_simlib' failed due to earlier errors.
Re: compile_simlib failed to compile for active_hdl with <number> errors
Hi @jeff_king,
I see that you are using 10.1 active HDL with vivado 2015.4. Can you please try using supported version of Active HDL 10.2SP2 and please let me know the outcome of it.
If you are still facing the issue then please share the compile_simlib.log and the secureip log file. Also, please make sure you are using supported OS with vivado 2015.4:
https://www.xilinx.com/support/answers/54242.html
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
Hi @jeff_king,
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
@bandi I am running this on Windows 10 so that must be the problem. I tried creating the libraries again for 10.2 with errors but since the OS isn't supported I will try upgrading to a later version of Vivado. If all else fails, read the manual, eh? Lol, thanks for your help!
