jehandad
compile_simlib fails to compile libraries for modelsim 10.5c on Vivado 2017.2
Vivado Version 2017.2
ModelSim version 10.5c (IntelFPGA Pro version)
The command I used to compile Xilinx Libraries is as follows:
compile_simlib -language all -dir ${lib_dir} -simulator modelsim -simulator_exec_path {$modelsim_path} -32bit  -library all -family  kintexu
The variables lib_dir and modelsim_path point to valid paths for output and modelsim binaries
Here is truncated output indicating the problem:
* COMPILATION SUMMARY *
* Simulator used: modelsim *
* Compiled on: Thu Jul 27 14:55:11 2017 *
* Library | Language | Mapped Library Name | Error(s) | Warning(s) *
* secureip | verilog | secureip | 1 | 0 *
* unisim | vhdl | unisim | 3 | 0 *
* unimacro | vhdl | unimacro | 1 | 0 *
* unifast | vhdl | unifast | 1 | 0 *
* emc_common_v3_0_5 | vhdl | emc_common_v3_0_5 | 1 | 0 *
Looking at similar posts on the forums the first culprit would have been the modelsim version, however that is listed as supported. Help would be much appreciated.
jehandad
By passing the -verbose switch to the compile_simlib command, we can generate log files for the compilation process. These log files indicate that vivado is looking for the modelsim binaries in modelsim_ae/bin/../linuxpe/* directory due to the -32bit switch. By creating a softlink named 'linuxpe' targetting the modelsim_ae/linux directory we can resolve this issue.
jehandad
