09-24-2010 11:53 AM
we are learning that in data flow modelling all the statements are executed concurrently while in behav. it is sequentially...
can u pls explain while executing concurrent statament compiler is at more than one place at any time!!!!
how this is possible??
thanx!!
09-24-2010 02:21 PM
d,
Hardware may have (and often does have) many elements, each element may operate at the same time (concurrent).
Imagine four 2 input NAND gates, they will provide four outputs, of the four dual inputs, all at the same time.
If you program hardware, you use a Hardware Description language (like verilog, or VHDL). Hardware can do as much as you require, all at one time, so you describe everything that you need to have done. The synthesis tool (not a compiler) builds the circuits, and connects them to perdform the designed task.
09-24-2010 09:41 PM
but sir,
if we have the statements in the data flow modelling as:
c<=a and b;
d<=a xor c;
now i am not understanding how the simulater can execute these 2 statements at the same time... i mean how can a simulater be at 2 places at the same time????
thanx!!
09-25-2010 05:51 AM
09-25-2010 04:10 PM
The simulator is simulating a hardware implementation and hardware operates concurrently. It isn't clear to my why you are concerned about ths.
09-25-2010 04:44 PM
Concurrent statements are executed by the simulator concurrently in SIMULATION TIME not the cpu time. The simulator will still execute each statement sequentially in the processor (CPU time), but it will arrange/schedule statements in a way to match what would happend in HW (i.e. concurrently). Using your example, the simulator could execute the instructions below sequentially so that the signal d gets the "xor" result of a and c from the previous time tick.
c_last_tick = c;
c = a and b;
d = a xor c_last_tick;
@deep01 wrote:
but sir,
c<=a and b;
d<=a xor c;
thanx!!
09-27-2010 10:09 AM
@deep01 wrote:
but sir,
c<=a and b;
d<=a xor c;
thanx!!
You need to find a good VHDL book that explains the concept of "delta time" and simulation cycles.
09-28-2010 01:37 AM
Hello deep01,
this is your animated simulator talking to you.
Let's simulate a very simple circuit consisting of two concurrent assingments like this:
c<=(a or b) after 10 ns;
e<=(d or c) and a;
The tesbench already told us to set all input's to '0'. (that is a, b and d), so the resulting signals c and e are also '0' now.
I won't explain how I reached this point now, but it's a good starting situation for our little simulation experience.
Since I am event driven, I will idle until something happens......
Oh, there's an event, coming on signal a at time T-0.
T_0: a <= '1'
Starting delta cycle 1:
Evaluate c<=a or b; c<='1' scheduled for T_0 + 10ns
Starting delta cycle 2
Evaluate e<=(d or c) and a; e <= '0'
That's all for this event, let's see what's on our list.... Ah, another event at T_1 = T_0 + 10ns
T_1: c <= '1'
Evaluate e<=(d or c) and a; e <= '1'
Nothing more? Testbench finished?
Ok, lets write the results to the waveform database, and terminate myself
Sayonara,
your friendly neighborhood simulator. ;-)
Hope you got an idea.
Have a nice simulation
Eilert
