betontalpfa
custom modelsim.ini file using Modelsim in Vivado?
How to use custom modelsim.ini file using 3rd party Simulator (Modelsim) in Vivado?
More precisely I want to add configs into my modelsim.ini, however the Vivado passes a generated modelsim.ini file to Modelsim, (which overwrites my modifications).
Is there a source (template) modelsim.ini file which can be modified permanenty?
Is there any TCL command to add lines to modelsim.ini?
I use:
  • Win10
  • Vivado 2017.4
  • Modelsim PE10.6d
betontalpfa
Finally I found that Vivado uses the modelsim.ini located in the precompiled library directory as the template.
 The simulation can uses custom modelsim.ini by modifying that modelsim.ini file.
betontalpfa
bandi
Hi @betontalpfa ,
Can you please close this thread by marking your post with solution as accept as solution.
Thanks & Regards,
Sravanthi B
