dislpay image on monitor
I am trying to implement contrast stretching algorithm on Spartan 3 (Using Xilinx 13.4). I just wanted know if it is possible to get contrast enhanced image as output( ie display it) by just using the simulator. So far as simulation is concerned my outputs are the modified pixel values written onto a text file, which I later convert into an image using MATLAB. Is it possible to directly convert these modified pixels into image at the output of the simulator, avoiding MATLAB or any means to integrate both(MATLAB and ISE simulator)?
fopen("wb") creates a binary file and fwrite("%u". ....) writes raw data of the item to the file. The combination of these two allow you to create a binary image file. This document http://www.w3.org/Graphics/GIF/spec-gif89a.txt specifies what a GIF file looks like and a basic one is pretty simple to generate (fixed header, no palette etc.). One should be able to develop a verilog gif writer in a day or so.
I guess you are using ise so systemverilog is out but you still can write an image file using verilog fwrite etc. functions. Some image files are not very complicated and it doesn't make much code to generate them.
Advisor
Advisor
As Muzaffer has said, you can just have it write images. Not much good for video, but a simulation won't produce good video anyway (it'll take ages to do a single frame). I strongly recommend having a look at the PGM (greyscale) and PPM (colour) image formats; they're human-readable and trivial to export manually.
@muzaffer
As you rightly pointed out I'm not working on system verilog. Can you please elaborate a bit more on using fwrite.So far I've written the pixel values onto a text file using fwrite. Now how do I proceed with generating an image out of this text file. Could you please suggest how do I go about with writing the code to achieve this.
