dual port bram issue
Update: run a sim, dual port ram show the same behavior in BRAM_controller mode see post 2
I create a dual port BRAM, with porta-> axi_bram_controller.  portb-> FPGA core.
but for some reason, it only read the data on last address I wrote too, no matter what address I change on porta or portb.
I look at chipscope, the ram output doesn't change when addr change
the 1st screen show last byte write to addr 1, and it seem working but then even addr=0 for porta/portb, its shows value write to addrs 1.
2nd screen is software write read from ram
3rd screen shows read from addr0 or 1 don't change output.
4th screen show data write correctly from software to porta addr=0
so I'm expecting at addrs 0 its 0 to 1f, but its not.
my portb_en =1 all the time.
Re: dual port bram issue
forgot the 32bit address is byte align so the lower 5 bits address is ignored
so I run a simulation dual port ram in BRAM Controller mode
I'm getting same result.  not matter what address I change(port a/port b), the data is stuck at last address I wrote.
wrote 000102030405060708090a0b0c0d0e0f101112131415161718191a1b1c1d1e1f  at addr 0 on porta
wrote 202122232425262728292a2b2c2d2e2f303132333435363738393a3b3c3d3e3f  at addr 1 on porta
enable both porta_en/portb_en, all address set to 0, write_byte = all 0, yet the dout shows the value from address 1.
