sonasc1
error: compile HDL simulation library
Hi,all
first of all, sorry for my poor english!
when i use "Complie HDL Simulation Libraries"  on my project, it report errors:
Processing command line ...
Reading the compxlib configuration file - 'compxlib.cfg' ...
Library Source Paths => 'D:/SETUP/Xilinx/14.6/ISE_DS/ISE'
Current Working Directory => 'C:\Users\Lam\Dropbox\SDR Research Group RF LAB\Tutorial_SDR_K54\TestQPSK_DUC\Test2_qpsk_DUC\qpsk_rx100_DUC'
Compilation Mode = FAST
Execute Mode = ON
Scheduling library installation & compilation for architectures: spartan3e
Scheduling library installation & compilation for libraries: simprim unisim xilinxcorelib edk
Signature:-
D:\SETUP\Xilinx\14.6\ISE_DS\ISE\bin\nt64\unwrapped\compxlib.exe -s mti_se -l all -p "D:/SETUP/Quartus altera/modelsim_ase/modelsim_ase/win32aloem" -arch spartan3e -lib unisim -lib simprim -lib xilinxcorelib -lib edk -exclude_superseded -intstyle ise
ERROR:Compxlib - COMPXLIB[sim]: Unable to automatically find executables for simulator 'mti_se' from the following paths:
D:\SETUP\Xilinx\14.6\ISE_DS\ISE\\lib\nt64
D:\SETUP\Xilinx\14.6\ISE_DS\ISE\\bin\nt64
D:\SETUP\Xilinx\14.6\ISE_DS\ISE\lib\nt64
D:\SETUP\Xilinx\14.6\ISE_DS\ISE\..\..\..\DocNav
D:\SETUP\Xilinx\14.6\ISE_DS\PlanAhead\bin
D:\SETUP\Xilinx\14.6\ISE_DS\EDK\bin\nt64
D:\SETUP\Xilinx\14.6\ISE_DS\EDK\lib\nt64
D:\SETUP\Xilinx\14.6\ISE_DS\EDK\gnu\microblaze\nt\bin
D:\SETUP\Xilinx\14.6\ISE_DS\EDK\gnu\powerpc-eabi\nt\bin
D:\SETUP\Xilinx\14.6\ISE_DS\EDK\gnuwin\bin
D:\SETUP\Xilinx\14.6\ISE_DS\EDK\gnu\arm\nt\bin
D:\SETUP\Xilinx\14.6\ISE_DS\EDK\gnu\microblaze\linux_toolchain\nt64_be\bin
D:\SETUP\Xilinx\14.6\ISE_DS\EDK\gnu\microblaze\linux_toolchain\nt64_le\bin
D:\SETUP\Xilinx\14.6\ISE_DS\common\bin\nt64
D:\SETUP\Xilinx\14.6\ISE_DS\common\lib\nt64
D:\SETUP\Quartus altera\modelsim_ase
D:\SETUP\VB6\Tools\WinNT
D:\SETUP\VB6\MSDev98\Bin
D:\SETUP\VB6\Tools
D:\SETUP\VC98\bin
D:\SETUP\Quartus altera\modelsim_ase\win32aloem
D:\SETUP\Quartus altera\modelsim_ase\modelsim_ase\win32aloem.
Simulator 'mti_se' is ignored.
and when i simulate my project with modelsim (i am using ISE 14.6 and modelsim se 10.1e, i get this warning:
ISE Project Navigator
WARNING: Failed to get the pre-compiled simulation library information. To resolve this issue, you can perform either of the following:
 - If the libraries are already pre-compiled, point to them using one of the following methods:
 * Set the MODELSIM environment variable to point to the modelsim.ini file
 * Set the WD_MGC environment variable to point to the directory containing the modelsim.ini file
 * Copy the modelsim.ini file to the project directory
 * Set the simulation library path in the "Compiled Library Directory" property in either the "Compile HDL Simulation Libraries" or "Simulate Behavioral Model" processes.
- If the libraries are not yet compiled, compile them by running the "Compile HDL Simulation Libraries" process or by running the 'compxlib' application on a command line, and then point to the compiled libraries according to the method described above.
Would you like to abort the simulation process now?
Note: To turn off this dialog box, set the "Ignore Pre-Compiled Library Warning Check" process property to true
Yes   No
so  , anyone could help me fixer these errors,thank you!
sonasc1
Ah, finally running!
my modelsim's version (Altera Starter Edition) is not compatibility  with ISE,
i installed ModelSim PE edition and successed! :)
vemulad
Does the above location contain modelsim executable modelsim.exe?
If not right click on "compile HDL simulation libraries" and select "process properties", please set the correct location to modelsim executable in simulator path option.
Deepika.
Deepika.
sonasc1
i installed Quartus Altera with modelsim SE and I'm sure that the folder above contain modelsim.exe
further, I cant not link unisim library with modelsim when i compile my project in modelsim! it report errors:
=====Library unisim not found.
=====Unknown identifier "UNISIM".
i dont know if these problems related to each ther?
have you ever met that problem ?
any one could help me,? please!
sonasc1
I need to simulate my project with modelsim, but ise can not running "Compile HDL Simulation Libraries" because of these errors.
so, what should i do now?
sonasc1
