error in System Verilog
why I am getting this error. The "System Verilog Cover group" is not supported yet for simulation. I am using 2016.4 version
Please use the latest Vivado version, 2016.4 is too old, which may not support covergroup.
Hi @sudheer397 ,
Please try using Vivado 2019.x or later versions of Vivado.
Thanks & Regards,
Sravanthi B
