error in modelsim from project navigator
i get this error when i am trying to run modelsim from project navigator. I compiled complxib and tried to run the simulation.
ERROR: Simulator version mismatch!
               The simulation libraries were compiled for the 'MTI_PE 6.6b' version, but
               the selected simulator is 'MTI_PE Edition'. Please recompile the libraries for
               the selected simulator version or change the simulator selection.
How can i change the selected simulator  to MTI_PE 6.6 b .  The only option in the xilinx ise 12.1 is Modelsim -pe -vhdl but cant fined the version number option.
Re: error in modelsim from project navigator
have you set correct path for modelsim PE in EDIT- preference intregrated Tools?
How do i do that?
I did set the simulator path while compiling HDL simulation libraries.
Also i have included simulator as modelsim -PE VHDL in Project-> Design properties.
I dont see modelsim -PE vhdl 6.6 b... ?
Newbie poutchou24
I have the same problem, need heeeeeeelp
Historian
Historian
You need to call your Mentor Graphics representative and buy ModelSim PE. It is not free. (It's about ten kilobucks.)
You need to set the simulator path in ISE. Go to Edit menu => Preferences...=> Integrated tools as shown in the attachment.
Apart from this if you can also try, Right click on the 'Simulate Behavioral Model' and uncheck "Ignore Pre-Compiled Library Compilation Message"
-PK
