xikun.dai
fail to generate vcs filelist following with script get_vcs_sim_files_RTL_proj.tcl
I just followed the
AR# 56490
to generate vcs file list, but met error during this procedure.
i saved the log file(error.log) and
attatched it for your reference
BR
Xikun
debrajr
Yes, the tool version given in the Release Notes is the minimum version needed. The higher version of the tool should work. The minimum required version for 2013.2 is Synopsys VCS and VCS MX (G-2012.09) or higher.
Debraj
vuppala
I hope this helps: http://www.xilinx.com/training/vivado/simulating-with-synopsys-vcs-in-vivado.htm
graces
As stated in the AR notes, this script must use the Synthesis Design Check Point IP option during IP output product generation. It will read the DCPs generated from IP OOC synth run and write simulation netlist.
What version of Vivado are you using?
If you use 2013.3 and above, you can run export_simulation command to generate a standalone run file for VCS. For more information, please refer to UG900. Of course you need to use the compatible VCS version.
xikun.dai
debrajr
get_files -compile_order sources -used_in simulation \
-of_objects [get_files <IP name>.xci] command can be used in your Vivado project to get a list of files which would be used in simulation for the IP.xci. This can be modified to suit your purpose (if the only intent is to know what files are needed for simulation). Other alternative would be to run Vivado Simulator which generates a .prj file in sim_1 folder of your project. This is the complete fileset for simulation. Tweak it to use in VCS.
Refer Xilinx Docs for details on get_files.
Debraj
xikun.dai
hi,
if we use vivado2013.2, what is the appropriate vcs version? vcs mx 2013.6
and ,how about vivado 2013.4?
BR
Xikun
xikun.dai
hi,
if you have the appropriate vcs version, can you capture a figure of executing the "vcs -id" on your linux console for us.
our IT is planning to purchase/install the VCS .
@xikun.dai wrote:
hi,
BR
Xikun
vuppala
The appropriate vcs version for Vivado 2013.4 is: vcs mx 2013.06
See the section "Compatible Third Party tools" in the following user guide: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/ug973-vivado-release-notes-install-license.pdf
xikun.dai
thanks,
currently, I know vcs mx 2013.6 is ok for vivado 2013.4.
so , can we use vcs mx 2013.6 for vivado 2013.2?
BR
Xikun
debrajr
Debraj
