li_zicong
failed to compile VHDL simulation libraries with VCS and failed to compile in VCS
I have been faced with two urgent problems:
========================1=====================
vivado failed to compile the simulation library.the summary indicate there are 5 errors while compile the unisim(3 errors), unimacro(1 error) and unifast(1 error) VHDL libraries. The error infos are as below:
1) INFO: Please refer to the messages between 'BEGIN_COMPILATION_MESSAGES(vcs_mx:vhdl:unimacro)' and 'END_COMPILATION_MESSAGES(vcs_mx:vhdl:unimacro)' in the log file compile_simlib.log for details of compilation error(s).
2) INFO: Please refer to the messages between 'BEGIN_COMPILATION_MESSAGES(vcs_mx:vhdl:unifast)' and 'END_COMPILATION_MESSAGES(vcs_mx:vhdl:unifast)' in the log file compile_simlib.log for details of compilation error(s).
3) Please refer to the messages between 'BEGIN_COMPILATION_MESSAGES(vcs_mx:vhdl:unisim)' and 'END_COMPILATION_MESSAGES(vcs_mx:vhdl:unisim)' in the log file compile_simlib.log for details of compilation error(s).
OS = Centos 6.6
Compiler version = VCS-MX-vj-2014-12
please check the attched compile_sim.log file
===================2==================
I still use VCS to simulate my code regardless of not having the right simulation libraries. It encounters errors in compile step and the vhdlan.log is provided for checking which I could barely understand. Is this because VCS can't parse the VHDL encrypted by Xilinx ?
How can I resolve all this ?
Thanks!
graces
You may want to check your environment settings, in particular, $VCS_HOME, $PATH.
vuppala
Hi @li_zicong
From the vlogan.log file, I see that you are using H-2013.06 version of VCS.
The compatible version of vcs for Vivado 2015.4 is: J-2014.12-SP2
See this answer record for more information: https://www.xilinx.com/support/answers/68324.html
Vinay
li_zicong
Thanks for reminding me!
I have both VCS-2013 and VCS-2014-mx installed on my system, set "/ecad/tools/synopsys/vcs-mx-vj-2014-12/bin" as "VCS simulator install path" in Vivado Options and "Simulator executable path" in Compile Simulation Libraries and choose VCS in Simulation Setting. How could that happen ?
graces
li_zicong
Thank you so so much!
li_zicong
After fixing the environment value problem, I could used VCS as my simulator. VCS GUI pops up too and starts to parse my source code, but it  encounters a error which is "No available context, VCS RUNTIME ERROR" after showing all my modules are compiled, Of course, simulation can not  start. I google it, but it seems that there are little problem concerned with mine. Do you have any idea? Thanks
graces
For the new error, it looks more related to VCS install/environment. I'd suggest that you contact VCS support for investigation.
