fopen fails on Vivado 2017.4 Windows simulation
Using Vivado 2017.4 simulator.
  • Binary data file located at project.srcs/sim_1/frames.raw
  • File added to simulation sources
  • File automatically copied to project.sim\sim_1\behav\xsim
  • fopen() always returns fp = -20000, which fread() later rejects with an error
Testbench snippet:
    reg [7:0] rxd;
    integer fp, ret;
    initial begin
      fp = $fopen("frames.raw", "rb");
      if(fp == 0) begin
        $display("Failed opening data file!\n");
        $finish(1);
      end
      ret = $fread(fp, rxd);
    end
TCL console reports: ERROR: File descriptor (-1) passed to $fread in file C:/<path>/project.srcs/sim_1/tb.v at line 163 is not valid.
Debugger shows fp == -20000, and the fread() did not load the expected values.
Switching directory using TCL console does not help:
    cd C:/<path>/sim_1
    pwd
    C:/<path>/sim_1
Moving the file to C:/frames.raw and opening with these methods does not help:
    fp = $fopen("C:/frames.raw", "rb");
    fp = $fopen("C:\frames.raw", "rb");
Intentionally changing file name to non-existent file returns fp = 0 instead.  So the error above is not a file-not-found error.
    fp = $fopen("nonexistent.raw", "rb");
Windows properties dialog shows Authenticated Users have read/write/execute/modify permission on the files (both in sim_1 and behav\xsim)
Similar problems were reported here without a clear resolution:
https://forums.xilinx.com/t5/Simulation-and-Verification/Vivado-cannot-find-data-file-for-my-System-Verilog-simulation/m-p/830250
https://forums.xilinx.com/t5/Simulation-and-Verification/fopen-returns-255/td-p/873249
Re: fopen fails on Vivado 2017.4 Windows simulation
Problem solved.  It was simply a syntax error in fread() that did not generate a warning.  Should have been:
    ret = $fread(rxd, fp);
not
not
