Observer pev.hall
glbl.v is not being loaded in my testbench
I'm trying to simulate a Verilog module inside my VHDL project. However the glbl.v does not appear to be loaded.
I'm currently using ISE 13.4. This did no appear to be a problem in 13.2. I'm currently in the process
Running: C:\Xilinx\13.4\ISE_DS\ISE\bin\nt64\unwrapped\fuse.exe -intstyle ise -incremental -lib unisims_ver -lib unimacro_ver -lib xilinxcorelib_ver -lib secureip -o C:/work/.../ise/toplevel_tb_isim_beh.exe -prj C:/work/.../ise/toplevel_tb_beh.prj work.toplevel_tb work.glbl
You can see that work.glbl is being referenced in the command. If I have got the option selected to load it.
ERROR:HDLCompiler:71 - "N:/O.87xd/rtf/verilog/src/unisims/RAMB36SDP.v" Line 204: GSR is not declared under prefix glbl
ERROR:Simulator:777 - Static elaboration of top level VHDL design unit toplevel_tb in library work failed
Observer pev.hall
Re: glbl.v is not being loaded in my testbench
I've found a work around. Creating a verilog module that is one level higher then my test bench like so
module test;
    toplevel_tb tb_inst(
endmodule
Observer pev.hall
module test;
endmodule
