amencharaabi
hello i have a problem in the test bunch in get no module file
im using vivado 2017.2
this is the program
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity dec is
Port (bcd:in std_logic_vector(3 downto 0);
segment : out std_logic_vector(6 downto 0) );
end dec;
architecture Behavioral of dec is
begin
process(bcd)
begin
case bcd is
when "0000"=>segment<="1111110";
when "0001"=>segment<="0110000";
when "0010"=>segment<="1101101";
when "0011"=>segment<="1111001";
when "0100"=>segment<="1001100";
when "0101"=>segment<="1011011";
when "0110"=>segment<="1011111";
when "0111"=>segment<="0001111";
when "1000"=>segment<="1111111";
when "1001"=>segment<="0000100";
when others=>segment<="0110111";
end case;
end process;
end Behavioral;
**** test bunch
library IEEE;
entity testd is
Port ( );
end testd;
architecture Behavioral of testd is
component dec port
end component;
signal bcd: std_logic_vector(3 downto 0);
signal segment : out std_logic_vector(6 downto 0);
begin
uut: dec port map( bcd=> bcd, segment => segment);
stimulus: process
begin
bcd<="0001";
wait for 100 ns;
bcd<="0010";
wait for 100 ns;
bcd<="0011";
wait for 100 ns;
bcd<="0100";
wait for 100 ns;
bcd<="0101";
wait for 100 ns;
bcd<="0110";
wait for 100 ns;
bcd<="0111";
wait for 100 ns;
bcd<="1000";
wait for 100 ns;
bcd<="1001";
wait ;
end process;
end Behavioral;
calibra
Voyager
Voyager
Which problem ?
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
amencharaabi
Problem in the simulation in the bench test
calibra
Voyager
Voyager
Again which problem !!!!
amencharaabi
Yes
amencharaabi
No module file
calibra
Voyager
Voyager
Post at least the simulator output
amencharaabi
No module file always the same problem
calibra
Voyager
Voyager
On the testbench remove
Port ( );
remove out
Please check the simulator outputs.
amencharaabi
I remove it and it still the same problem
calibra
Voyager
Voyager
share a screenshot
