[help]Model Sim error :# No design specified
While I am using the Endpoint block plus v1.9 for PCI Expree, I do exactly under the instructions in pcie_blk_plus_gsg343.pdf to test the example generated with the core. But when I want to simulate the example, I encountered an error:
I first open ModelSim,then type this command:"cd e:\xxx\xxx\xxx\simulation\functional " to change the directory,then type the command in pcie_blk_plus_gsg343.pdf "vsim -do simulate_mti.do". But the error occured.I tried several times but in vain.
Can anybody know the reason and solution to the problem?Thank you very much!
Hu LI
Re: [help]Model Sim error :# No design specified
You need to run vsim -do simulate_mti.do from a dos command window, not from within Modelsim.
Cheers,
Jim
Message Edited by jimwu on 03-12-2009 06:17 AM
Cheers,
Jim
Can you copy the error verbatim so we know exactly which design module is ModelSim unable to bind?
Eddie
Cheers,
Jim
Cheers,
Jim
Oh,I see ,thank you very much!:smileyhappy:
Hu LI
