Newbie zj_zilinx
how to compile simulation libraries iv vivado2012.3
when I use TCL command "compile_simlib" to compile simulation libraries,I was to simulator modelsim is ignored,I used the command as follow :"compile_simlib -family kintex7 -language verilog -library all -simulator modelsim"
Re: how to compile simulation libraries iv vivado2012.3
Try the below command.
complie_simlib -family kintex7 -language verilog -library all -simulator modelsim -simulator_exec_path <path_to modelsim.exe>
If this works, the modelsim path was not set to the %PATH% environment variable.
