Observer chienpingwong
how to do a simulation with a bidirection port in the project ?
Hi :
I am always wondering how to do a simulation with a bi-direction port in the project ? What I did was, build up two versions of Testbench. One declares it is a input port and the other declares it as an output port.
Is that the only way ? Or  ...
Thank you
Jack
Historian
Historian
Re: how to do a simulation with a bidirection port in the project ?
@chienpingwong wrote:
Hi :
Thank you
Jack
If the port pin is an inout, then one has to assume that inside the FPGA there is the proper output enable logic to drive it when required.
Do the same thing in the test bench. The test bench needs to declare the signal connected to that port, and drive it with a valid logic level at the appropriate time and drive it to 'Z' otherwise.
