Observer farhathsuj
how to generate sine wave...
i have simulated the https://surf-vhdl.com/how-to-implement-sinusoidal-dds-vhdl/,this program in model sim ,how to get the sine wave. pls refer the output1 given below. and pls give a idea  about this
Re: how to generate sine wave...
Hi @farhathsuj,
Right click on the signal name, then select "Properties", next select "Format" tab, then click on the "Analog" type option and then change the scale as required in the analog display window.
Hi @farhathsuj,
Observer farhathsuj
thank you @shameera,it has hepled a lot and i have got the output as shown below ,but im not getting correct sine wave...
Observer farhathsuj
Three possibilities to look at.  You may be displaying a signed number as unsigned, you may be displaying an insigned number as signed, or one of yur busses needs an extra bit and your signal is overflowing, thus wrapping around.
