how to generate xilinx IP core structural simulation model
Hi, all,
The core generator only generates *.v or *.vhd, which is the functional simulation model of the IP core, how can I get the structural model for  post synthesis simulation or post PAR simualtion?
Open Coregen standalone, create a new coregen project. In project options, select "Generation" -> Preferred Simulation Model -> Structural
Thanks graces
Can it be done inside PlanAhead/Vivado Ip Catalog ?
Or I should remove core first and then recreate it via standalone CoreGen ?
thanks!
