how to snap "additional Marker" to waveform edge
In Vivado simulator, the primary yellow marker can snap to a waveform edge using the mouse click.
But when we add additional marker that are blue, the snapping only work the yellow primary marker not on the added blue marker.
Does anyone know how to snap to the waveform edge on these added blue Marker in the waveform simulation
Re: how to snap "additional Marker" to waveform edge
@tchin123
The procedure for snapping a marker to a waveform edge is described on pages 99-100 of UG900(v2019.1).
The general method is to first create the marker (right-click, Markers, Add Marker).  Then (this is the important part), grab the marker line with the mouse cursor at a point that is over the waveform whose edges you want to snap to.  Now you can move the marker line left and right. When done this way (and as described in UG900), you will see a circle on the mouse cursor that is usually hollow but becomes solid when the marker is snapped to an edge on the waveform.
Mark
This work as described for the additonal Marker by dragging, thanks
Currently, The "mouse click" snaps the primary marker to any edge of the selected waveform. Is there a way to designate a secondary Marker then "clicking "any edge to do the same.
