seban90
how to test MIG core in VCS
I generated mig core in vivado 19.1.3 and made simple testbench with ddr4 model (simulation model from micron website).
simulation runs in vivado, but it cannot run in vcs because of segmentation fault.
Is there what I missed?
yangc
How do you simulate in VCS? You can refer to https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug900-vivado-logic-simulation.pdf#page=38
And compile the libraries first if you use a third-party simulator.
seban90
Thank you for your response.
My simulation target is huge size of asic system which I modified to fit it in fpga.
In my understanding, mig or other related secure ip can be compiled by vcs (as standalone compilation environment) even if all are encrypted.
also, I listed all required files to compile them by vcs and vlogan was able to compile all.
this is my option
In Makefile,
VLOGAN = vlogan
VCS = vcs
VLOGAN_OPT +=  -full64
VLOGAN_OPT +=  -l vlogan.sim.log
VLOGAN_OPT +=  -work work
VLOGAN_OPT +=  -timescale=1ns/1ps
VLOGAN_OPT +=  -error=noMPD
VLOGAN_OPT +=  +v2k
VLOGAN_OPT +=  +libext+.v
VLOGAN_OPT +=  +define+ALL_DEFINES_FOR_FPGA
VLOGAN_OPT +=  +systemverilogext+.sv
VLOGAN_OPT +=  +systemverilogext+.svp
VLOGAN_OPT +=  +systemverilogext+.svh
VLOGAN_OPT +=  -assert svaext
VLOGAN_OPT +=  -f sim_file_lists.f
VELAB_TOP += -full64
VELAB_TOP += debug_access+all
VELAB_TOP += -deraceclockdata
VELAB_TOP += -top glbl
VELAB_TOP += -top testbench
