i got different simulation result compare on different computer
this is my friend code test on basys3 machine about 4-bit lfsr. the rar file is my code
Debounce https://www.digikey.com/eewiki/download/attachments/13599139/DeBounce_v.v?version=1&modificationDate=1365097105920&api=v2
source code
`timescale 1ns / 1ps
module Ex1(sr,pb,load,x0,clk);
    input clk;
    input pb;
    input [3:0] x0;
    input load;
    output reg [3:0] sr;
    wire x;
    reg reset=1;
    wire pb_out;
    DeBounce_v db (clk,reset,pb,pb_out);
    assign x=sr[3]^sr[2];
    //always @(posedge clk)
    always @(posedge pb_out)
    begin
    if (load)
        sr={sr[2:0],x0};
    else
        sr={sr[2:0],x};
        end
endmodule
TestBench:
module Test_Ex1(
reg clk;
reg pb;
reg [3:0] x0;
reg load;
wire [3:0] sr;
Ex1 uut(
.clk(clk),
.pb(pb),
.x0(x0),
.load(load),
.sr(sr)
initial begin
clk=0;
x0=4'b0101;
load=1'b0;
#100;
load=1'b1;
x0=4'b0101;
#100;
load=1'b0;
x0=4'b0101;
#100;
load=1'b1;
x0=4'b0101;
#100;
load=1'b0;
x0=4'b0101;
#100;
load=1'b1;
x0=4'b0101;
#100;
load=1'b0;
x0=4'b0101;
#100;
load=1'b1;
x0=4'b0101;
#100;
load=1'b0;
x0=4'b0101;
end
initial begin
forever begin
#30;
clk=!clk;
end
end
endmodule
myfriend.pngthis is from my friend
me.pngmy simulation,
dror_m
input [3:0] x0;
sr={sr[2:0],x0};
first of all u r pushing 7 bits to 4 bits
the difference in simulation: in one u put sr and in the other SR (capital letters), Verilog is case sensitive
dror_m
input [3:0] x0;
sr={sr[2:0],x0};
1)about this one input [3:0] x0;
i already fixed i my code.
2) about SR and sr, i think they are not the big problem. Since even if i put those are the same character they doesnt work on my machine
And as far as i concernred .sr(SR) this one also work, cause i already write a lot of different code in other labs and i write different input in source code like C and simulation CLK and in simulation code i write for example lfsr uut( . C(CLK)) it still accepts my code and run the simulation perflectly fine
by the way do you have the simulation output like my friend, if you answer yes i will modify my code gain
graces
I could not reproduce the first simulation waveform. As I see it, pb_out remains X and doesn't trigger the sr toggling.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs.
my friend's simulation output also looks like that, what i want is to let the [3:0] sr to have the output like my friend.
i think it must because that my machine dont have Basys 3 on the board then i have to use XC7A35T-1CPG236C as Basys3, my friend just acc essBasys3 on his project device but i dont have it. THis trivia different project part may lead to this problem.
that pb_out displays X is acceptable
